Wrecked 3215HST
/ Wrecked 3215HST #1
Farmerboy
Parker, Pennsylvania
Mahindra 85 / Ventrac 4500P
Last Sunday I had the misfortune of riding my 3215 (that I purchased on Easter weekend and which only had 80 hours) over a ten-foot high embankment into a field stream. I was using the bucket of my unit to haul fence posts around the property as I put them in with a sledge. I was running parallel to the drop off, about 8-feet back from the edge, when I decided to turn around and head back. The area above the embankment had approximately a 10-degee down slope leading up to the drop off.
I began to reverse my direction and back up the slope until I was almost exactly perpendicular to the edge. At almost the exact instant I got perpendicular, the wheels broke loose. The ground was covered with pine needles which acted like marbles. My R4 tires couldn't get traction. So, although I was in reverse, and the wheels were turning in reverse, the tractor began lurching forward. Oh, and I was in High range....and the 4-wheel-drive was off.
As stated before, I was about 8-feet back from the edge. Well, when I went to slam on the brake, my foot caught both the brake AND the gas! On many HST models (regardless of the make) the gas is right in front of the brake. As I found out, this isn't the best location when one is panicked and looking for the brake.
By now, I was only a couple feet from the edge. With foot on the brake and not on the gas, I tried to turn the wheel hard to the left. However, due to the weight of the machine and the terrain, the tractor wasn't turning. Rather, the unit just kept lurching forward.
Lastly, I tried to drop the loader. However, there just wasn't enough time for the hydraulics to respond.
With the front tires already going over the edge, I thought, "Well...this is it."
The tractor and I rolled and flipped our way to the bottom. At some point I came free (wasn't wearing a seat belt). I remembered looking over my shoulder and seeing the tractor stand up. I was able to throw myself forward before it came back down. However, when the unit did come back down, the left rear tire rolled over my right leg, pushing it down into the mud of the stream, and effectively trapping me under it.
My wife, who saw the whole situation unfold, was able to get her grandfather to come down with another tractor and lift my 3215 off me.
Although I was able to walk away, I did end up spending two days in the hospital with a severely fractured wrist.
Reality set in when I contacted my insurance company a few days later to report the loss. Some other guy the week before rolled over the exact same unit, except he didn't walk away.
I wanted to share this experience with the forum just to remind folks how dangerous these machines can be. Don't ever forget to respect these machines.
Going forward, my bones will heal, my dealer will help me fix my machine, and I'll certainly count my blessings more than I count my problems.
Have a safe and happy Father's day.
/ Wrecked 3215HST #2
Glad to hear you're okay. As you note, could've been much worse.
Looking at the picture you included it is pretty impressive that the ROPS bent but didn't collapse. I expect the ROPS to work when one rolls over but your description sounds like a hard fall quite a ways down.
After reading this and other stories, this new tractor owner is thinking 4WD should be engaged near any hill and the FEL should be as low as practical at all times. I know that's what the safety brochure says - time to start making it a habit.
/ Wrecked 3215HST #3
Glad to hear your OK.
That could of easily gone the other way and we would be mourning your loss right now.
SEATBELT SEATBELT SEATBELT SEATBELT
/ Wrecked 3215HST #5
Whew, close one Farmer. I have a hard time with the obligatory seat belt recommendation. I certainly suppose in many instances, the seat belt can be helpful in saving one's skin. Just not all instances. If I had one on the day I side flipped my JD., I would of cracked my skull open from the force of the side impact as the tractor hit the ground. Instead I was tossed off the tractor as it was going over and actually landed on my feet. We had a guy drown around here in a shallow stream gully about 10 years ago. He had his seat belt on while mowing near the 5' embankment over the gully. It gave way and tossed and rolled his machine into the gully. They surmise he was knocked unconscious at impact. Had he not been tied to his machine, he may have survived. I guess it is for us to judge our particular circumstance as to whether or not a seat belt is warranted instead of always obliging to a blanket statement no matter what or how we are using our machines. The way you describe your accident, do you feel you would have benefited more with the belt on?. Thank you much for bringing this to light and glad you were not severely injured.
/ Wrecked 3215HST #6
You are lucky to be alive still. As you know now you should have been wearing your seatbelt. I do not wear mine all the time but there are two times where I always wear it, when I am on the road driving the equipment to the field and if I am working near ditches or any type of drop where I could potentially roll the tractor.
I am glad you are ok and hopefully your wife will let you keep the tractor when this is all said and done. Then again, if she is pushing for you to get back on it fast I might question her intentions;)
/ Wrecked 3215HST #7
I just got my 3215 delivered Thursday, and have put about 8 hours on it. I agree with you on the pedal situation, I would much rather have a hand emergency brake, rather than reaching over the go pedal to hit the brake. Glad to hear you are OK.
/ Wrecked 3215HST #8
Thank you very much for sharing, I am glad you are ok.
We all learn from these shared stories, greatly appreciated you'd take time to type so much with a fractured wrist.
Hoping you stay safe.
Sincerely,
Joel
/ Wrecked 3215HST #9
Wow! That must have been a heartstopping moment!
Good that you are OK.
Thanks for the post.
WarHammer
/ Wrecked 3215HST #10
Wow, glad you were for the most part unhurt. It's definitely a reminder that all large machinery and cars need to be shown respect to the amount of damage they can do. Life can change in an instant.
by the way, here's a link I saved a while ago....I think someone posted it on here. It just shows how easy it is to roll a tractor even if you aren't on a steep hill or ditch.
Tractor Overturn, H.J. Sommer III
/ Wrecked 3215HST #11
Sure glad you are OK.
It won't help you any for what has already happened, but for others and for you in the future, if 4wd is engaged, the brakes will stop the front tires as well as the rears. It is a huge help in such situations.
/ Wrecked 3215HST #12
How scary. Your tractor looks identical, well, less the slight lean to the left, as mine. It's like this happened to mine.
Patrick
/ Wrecked 3215HST #13
I too am glad to hear that you are okay. There is nothing worse than that sinking feeling you get when you start sliding on a piece of machinery.
I was out mowing at my last place which was very hilly with my older Case 4x4 which weighed in at eight tons. Having been out on the blacktop township road, I had taken it out of four wheel and forgot to put it back in.
I had driven out along the top of a field then turned left to go down and as soon as I did, the rear wheels lost traction and locked up and away I slid with my batwing pushing me. Somehow, I had the presence of mind to drop the mower. That and the hill leveling out stopped me before I went into the woods.
I slid on ice already with 380 bushels of manure pushing me with the tractor in four wheel. When I ran out of gears with the power shift, the spreader passed me and dragged me into the bushes. Once again, the damage was only to my "jockies". That and a new PTO shaft.
/ Wrecked 3215HST
Just a quick update - My Dealer came yesterday to pick up my 3215. Checked the fluids, looked it over, added some fuel, and started it up. The tractor smoked for about 10 seconds (was flipped over for 4 days and hasn't been turned on since the accident on 6/8). The mechanic drove it around the barnyard and was able to drive it right up on the trailer.
I'll post an update once the damages are totaled.
Oh, and 5 more weeks in the cast for me.
JCB TELESCOPIC FORKLIFT (A65053)
JCB TELESCOPIC...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
2020 JOHN DEERE 333G SKID STEER (A65053)
2020 JOHN DEERE...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
