WOW: R&R clutch on a 5603 cost $4300
   / WOW: R&R clutch on a 5603 cost $4300 #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
My neighbors 5603/cab tractor stopped moving between unloading truck load of rd bales. After 2 dealer service calls that failed to remedy the problem tractor was hauled to dealer. Service manager stated clutch was bad to the tune of $4300. Tractor was bought new and had around 3700 hrs on tachometer.
   / WOW: R&R clutch on a 5603 cost $4300 #2
Jim,
What does a wet clutch set up generally need in a rebuild?
My only experience is the 40 or 50 series rowcrops. Clutch plates and renewing seals in the operating pistons. The way I understand the 5603 has a dry pad clutch
   / WOW: R&R clutch on a 5603 cost $4300 #4
Jum,
Which model? The 5603 built in Brazil is a 75 hp tractor with a dry clutch, the other is a 99 hp with cab and 12/12 direction reverser. According to Tractordata.
This one has a power reverser. I didn't know there were 2 different 5603's
   / WOW: R&R clutch on a 5603 cost $4300 #6
I don't know either way myself but would think the PR has a wet clutch, might be wrong info on tractor data too. At any rate if the price to change a dry clutch is $4k plus I need to make more money for my work.
On my Kubota M7040 with hyd shuttle it has a dry damper clutch but the fwd/rev clutches are the reverser clutches. I was thinking the 5603 might be similar but I could be WRONG. Here's a parts schematic of what I find in the 5603 parts catalog.
You need to understand the $4300 includes 2 hauling trips @ 35 miles one-way($150 per trip),2 service calls & DIAGNOSTICS!!!
   / WOW: R&R clutch on a 5603 cost $4300 #9
Could they be talking about the reverser needing to be rebuilt? It must have clutch packs.
What would a 5603 with 3700 hours be worth if repaired?
There was one similar to my neighbors tractor with only 1100 hrs for $25000 on DFW CL. $4K to rebuild a hyd reverser sounds high to me BUT parts key #26 is this part.
RE225848 Cylinder ADD 2,890.89 USD
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
ASCO Transfer Switch (A52377)
ASCO Transfer...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
