Wow! All these different PTO splines/sizes!??
   / Wow! All these different PTO splines/sizes!?? #1
jimgerken
Minnesota
John Deere 3720
Can anyone point me to a reference like a manufacturers page or something that shows the different PTO shaft spline configurations? I have a mid PTO on a JD that has 15 splines and is 1" OD. I know the standard PTO is 6 splines @ 1 3/8". It would be nice to know what I'm asking for as I start to shop for a new shaft for my homebuilt snowblower. Thanks...
   / Wow! All these different PTO splines/sizes!?? #2
On your JD the mid PTO is probably 1000RPM . The 6 spline 1 3/8 is for a 540 RPM PTO. So now you know!
The mid PTO on my 3020 is a 1 3/8 and I think 13 spline- it is 1000 RPM only. The rear PTO is set up for both--all ya gotta do is switch shafts. Hope this helps! Good luck!!
   / Wow! All these different PTO splines/sizes!?? #3
Before standardization got the PTO shafts all the same it was sort of "manufacturer's choice". The early 8N Ferds and also the Ferguson tractors had a smaller shaft. My late forties Case VAI had an adapter on it to go to a smaller size from standard so evidentally the previous owner had a non-standard implement from another manufacturer to power up. I THINK John Deere has always had the standard size spline for 540 RPM, clear back to the inception of the PTO shaft in the two-cylinder models. The belly PTO was a different story, and I don't know what they ended up to be and even if they are some kind of standard size. Early Allis-Chalmers tractors had the pto under the belly with a shaft to the rear. So many variations!!!! Dave
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2017 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2017 Ford F-450...
2013 Ver-Mac Solar S/A Towable Trailer Message Board (A49461)
2013 Ver-Mac Solar...
EZ-GO GOLF CART (A51243)
EZ-GO GOLF CART...
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
1999 John Deere 566 Round Baler  Net & Twine, Reliable Performance (A51039)
1999 John Deere...
