Woven Wire Fencing
   / Woven Wire Fencing #1
Philip_L
Folsom, LA
Kubota L185 2WD
Guys
I am fencing in a few acres for some cattle and am planning on 47" field fence topped with 2 strands of barbed wire. I can get either Red Brand 1047-6-12 1/2 with a hinge knot (vertical wires are individual), or Sierra brand 1047-6-13 with a square knot (vertical wires are 1 piece). Also the red brand has 10 ga top/bottom wires with 12 1/2 ga filler wires while the Sierra has 10 1/2 ga top/bottom wires with 13 ga filler wires. Having only run straight barb wire fencing in the past, I am unsure as to what are the advantages of the 2 knot styles and the minor differences in wire ga. Prices are comparable. What would you guys recommend
Philip
   / Woven Wire Fencing #2
is your land level? the hinged verticals are meant to follow the contour of the land. i just installed some unhinged on sloping land and it went up just fine. the gauge difference is not significant.
Yes, the land is fairly flat with only a few slow gradual dips here and there
2011 Ford F-350 Knapheide Service Truck (A54814)
2011 Ford F-350...
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53473)
2016 KBH...
2013 Vermeer BC900XL Towable Brush Chipper (A52377)
2013 Vermeer...
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
