Would you clean your mower this way?
   / Would you clean your mower this way? #11
Those BOYS obviously copied a similar video that has been floating around on YouTube for awhile. Getting off the Tractor while still running the mower was plumb STUPID. I, personally wouldn't put my hands on the mower blades while the tractor was still running either. Or checking the belts. Unforseen circumstances can occur at any time, and the end results aren't nice. Totally absurd and immature Behavior. Just my thoughts.
   / Would you clean your mower this way? #12
Same here...I just dip the tail in at the two low spots where we usually fish...to keep it mowed down..He actually pretty much submerged his mower and it was a finish mower with belts not a bush hog....right ?
Yes, you are correct.
   / Would you clean your mower this way? #13
Nope!
   / Would you clean your mower this way? #14
Not in my pond or with my mower. Nothing good is going to come out of that deal.
   / Would you clean your mower this way? #15
That youngster obviously hasn't had to pay for or install new spindle bearings.
Ayep. Hot bearings going into cold water will cause the air/grease in the spindle the shrink causing a vacuum in the spindle which the water will be more than happy to fill...
Aaron Z
   / Would you clean your mower this way? #16
Dropping spindles/bearings/deck into water & then also lifting powered up into/out of water will do wonders for the torque amplification/loading to the PTO/tractor........... + potentially sending grease & oil into the pond ?
It's all a question of what gives out first the bearings (seize) , the deck (rusts out), the tractor PTO or his pocket when the EPA hands out a fine for polluting a pond/waterway..............then again he may not live long enough to find out, the way he dismounts the tractor with the PTO engaged & delights in being in such close proximity inspecting spinning blades, maybe he's tested that spinning PTO shield is working by grabbing it...........
Hey, with so little understanding of basic implement operation & safety, where's the video of him washing the tractor submerged in the pond when running - he's obviously is not a tractor operator, perhaps a failed submariner or a reject crash test dummy?
We have a lot to thank YouTube for, including globally identifying these type of idiots......
IMO, regularly cleaning implements /tractors only with water generally does nothing to increase their life expectancy - instead blowing clean post each use with compressor air causes far less deterioration (than forcing water into places it was never meant to go), supplemented by (as appropriate) seasonal/annual washing/drying (again with compressed air)/waxing/detailing, including the coating of implemeents with a suitable rust/corrision inhibitor such as lanolin or penetrol..etc.
   / Would you clean your mower this way? #17
Probably burnt the clutch pretty good trying to start the PTO at full throttle with the blades completely submerged! Spinning PTO shield isn't too big of deal though since it has no power behind it. Not recommending anyone try it but usually you can hold the pto shield while the shaft inside is turning. Even the little chain some guards have is a pretty small chain. That kid is an idiot! An extension for an air blow gun is great for cleaning a mower deck without causing any damage. I made one out of copper tubing about 18" long and brazed it to the thread in nozzle for a blow gun. I got the idea from a golf course I worked at. 95% of the grass underneath will come off. Every once in a while they'd use a garden hose to do a complete cleaning.
2004 Chevrolet C5500 Flatbed Service Truck with crane, VIN # 1GBE5C1214F513547 (A57453)
2004 Chevrolet...
1791 (A58375)
1791 (A58375)
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND64FDGH1772 (A57453)
2015 Freightliner...
John Deere 6ft Rotary Brush Cutter Tractor Attachment (A56857)
John Deere 6ft...
1000 GALLON NURSE TANK (A52708)
1000 GALLON NURSE...
2197 (A58376)
2197 (A58376)
