Would you clean your mower this way?
   / Would you clean your mower this way? #2
Probably not. I'd end up in the pond. :laughing:
The garden hose cleaning nozzles on my rider deck don't get that much stuff off, maybe the deeper water and more volume does a better job?
   / Would you clean your mower this way? #3
Nope! Not good for the machine and too much chance for the tractor to end up in the water!
   / Would you clean your mower this way? #4
Has bad idea written all over it.
   / Would you clean your mower this way? #5
I've done something similar...I back up to my ponds edges to cut the bank and in a couple of low spots I let the bush hog sit in the water and rinse off...I don't do it as long as he did or as I high RPM and I sure don't get off while it is running much less walk around in front of the discharge chute...
   / Would you clean your mower this way? #6
That youngster obviously hasn't had to pay for or install new spindle bearings.
   / Would you clean your mower this way? #7
Ah, youth... what can I say..They just don't know any better. Also did anyone notice how the nice PTO shield rotated also? What is the point of having a PTO shield if you don't chain down both ends? Oh, well it is not my mower, and not my kids.
James K0UA
   / Would you clean your mower this way? #8
Not a chance. I dip the tail of my brush hog in the water a little but only to mow right down to water's edge. The spindles of that finish mower aren't going to like that water in the bearings.
   / Would you clean your mower this way? #9
What could possibly go wrong? :eek:
   / Would you clean your mower this way? #10
Same here...I just dip the tail in at the two low spots where we usually fish...to keep it mowed down..He actually pretty much submerged his mower and it was a finish mower with belts not a bush hog....right ?
2001 Kubota KX61-2 (A55272)
2001 Kubota KX61-2...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
NEW HOLLAND HAY CUTTER (A58216)
NEW HOLLAND HAY...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
