Would you book a trip to outer space or under sea?
   / Would you book a trip to outer space or under sea? #121
   / Would you book a trip to outer space or under sea? #122
Here's a news report of one retired submarine captain offering the theory that the carbon fiber, titanium, and plexiglas had different rates of expansion and contraction that could have worked the seal loose over repeated dives. A second Titanic tragedy: The failure of OceanGate's Titan
And a 2022 CBS interview with Stockton Rush about the construction of the Titan in which he discusses the safety issues including the crackling noise. OceanGate CEO Stockton Rush talks Titan sub's design, carbon fiber hull, safety and more in 2022 interviews
   / Would you book a trip to outer space or under sea? #123
The porthole is missing from the end cap
Rush had said that you'd get a ton of advance notice if it was failing due to crazing long before collapse
I'm trying to decide, if the cylinder (carbon fiber) collapsed, would that induce the destruction of the window? Would the sudden increase of pressure inside the sub pop the window "off" (though it was bolted on)?
Perhaps if the window collapsed first, the blast of water coming in from it may have damaged the inside of the cylinder, leading to its collapse as well?
   / Would you book a trip to outer space or under sea? #124
My guess, and it is only a guess, is that pressure collapsed the cylinder and caused the porthole assembly to blow off like a cap popping off a soda bottle that got squished. The Titan personnel chamber appears to have been unique in having a cylinder for 5 people compared to other submersibles like the Deepsea Challenger that only has a small sphere for one person. Comparatively speaking, there was a lot more surface area for pressure to build against the Titan pressure chamber. My logic would therefore be that if you have a larger pressure area, you'd want to build the thing even stronger.
Stockton Rush is quoted as having said a number of things in the CBS interview, including things about being able to react to warnings and make it back to the surface that today strike me as eerie. He answered several questions in the interview similar to those that various TBN members have been asking in this thread.
   / Would you book a trip to outer space or under sea? #125
I just saw a headline which stated they have found human remains. Once again, I refused to click on it.
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
CASE IH MAXXUM 115 TRACTOR (A60430)
CASE IH MAXXUM 115...
FARMHAND 827 FEED MILL (A60430)
FARMHAND 827 FEED...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
