Would this motor work for a stump grinder
   / Would this motor work for a stump grinder #31
Carl
I would suggest that you try to find an existing cutter wheel or junk machinery wheel/pulley that you can adapt to your project. IMHO this would be easier than trying to build on from scratch (Don't reinvent the wheel so to speak - sorry I couldn't resist!). There has been a lot of discussion about wheel diameter, RPMs, blade tip speed, etc. Again, I suggest you look at existing stump cutter designs for cues on how to build your own. Below are a few sites I found which provide info on wheel diameters and RPMs.
If you take the circumference of the wheel (pi x diameter/12) or (3.1415 x dia in feet) and multiply by RPM you will get the blade tip speed in Ft/min.
You will see that most of these cutters run in the range of 5000 to 7000 ft/min blade tip speed. The exception I believe is the Power Trac cutter. Info on the PT is not that easy to come by, but there is a link below indicating that the 400 series cutter motor is a 3 cu in. At a flow of 8 gpm that puts RPM in the range of 600 RPM. An 18 inch wheel running at 600 RPM would have a tip speed of 2825 ft/min. My experience with my cutter (which is based on a 400 series) was that I thought that the blade speed was a little slow and would be better if made a little faster.
It doesn't matter how you spin the cutter whether hyd motor or PTO shaft, the key elements are blade tip speed and sharp blades.
So, you can start with a blade design and find a suitable motor (and pulley/sprocket system if you choose to go that way) or start with a motor and size the blade to match.
Stump Grinders-BeeLine Stump Grinders-Sales & Stump Grinder Rentals
Stump Grinder - Tractor Mounted
Stump Grinder
Worksaver PTO Powered Stump Grinder
http://www.tractorbynet.com/forums/power-trac/29087-pt-stump-grinder.html?highlight=stump+grinder
No, I have nothing, not even the drill press. Making sure I ask twice and buy once (both to you guys and my wife).
I am out till Monday night. Have a great weekend and I look forward to seeing what you got David..
Carl
   / Would this motor work for a stump grinder #33
Well the good part about where you live is that there are plenty of used drillpress' running around your neck of the woods, or within reasonable shipping from you. A good drill press here will cost what a fair milling machine will cost out there. If you get stuck, maybe I can find someone with a homeshop willing to help you out within reason. I never miss a chance to buy a machine tool, as is obvious by my overcrowded garage!!
David from jax
Tool King 12-Ton Hydraulic Pipe Bender (A59076)
Tool King 12-Ton...
2007 GMC 2500HD (A56435)
2007 GMC 2500HD...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2017 Peterbilt 348 Hood 7000 Grapple Truck (A55973)
2017 Peterbilt 348...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
