Would this damage remote valve
/ Would this damage remote valve #1
BeezFun
Elite Member
IL
Kubota B2710
Accidentally had my remote valves connected wrong: Tank port was connected to what was actually power beyond hose and Power beyond port was not connected to anything. Of course I realized this as soon as I tried to use the other hydraulics, but would this damage the valve?
/ Would this damage remote valve #2
If you pressurized the tank port for a period of time you could extrude the seals on the ends of the spoils. Momentary pressure you probably didn稚 hurt anything.
With the power beyond port plugged your pump was at relief pressure. Again for a short period of time this should not be a problem.
/ Would this damage remote valve #3
Only two ways to find out. Correct the problem and run it or tare everything apart first
Put it back together correctly and everything works.
Rogator RG1100 (A63118)
Rogator RG1100...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
STEPP SEALCOATING MACHINE (A59910)
STEPP SEALCOATING...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2015 FREIGHTLINER...
