Would these claimed weights be legal behind this truck? (Ram 3500)
   / Would these claimed weights be legal behind this truck? (Ram 3500) #1
awhelan
killaloe on
410 JD
I found this post on my local KIJIJI today
Float Services | farming equipment | Kawartha Lakes | Kijiji
Would there be any way to legally tow the weight this guy says he's licensed for?
It's in Ontario Canada
If it's legal, It might allow me to move my backhoe myself if I can find a similar set up.
   / Would these claimed weights be legal behind this truck? (Ram 3500) #2
What's legal and what's smart are often two different things. Common sense tells me the guy is often pulling a lot more weight than that truck is designed for.
   / Would these claimed weights be legal behind this truck? (Ram 3500) #3
My cottage is down 127, just before Whitney. We drive by your door to get there. I can tell you, I sure wouldn't want to have that much weight behind that little truck on some of the hills around you.
   / Would these claimed weights be legal behind this truck? (Ram 3500) #4
It is amazing how many people don't get it. It is not how much weight you can pull but rather how much weight you can stop.
My BX2200 can pull a locomotive. Don't want to be on it when it is time to stop.
I cannot imagine he would not be pulled over and weight checked by a LEO.
LOL Thats what I was thinking too!
My backhoe is 14k lbs give or take, I dunno if I'd want to try coming down the hill into Madawaska on Hwy. 60!!
That is, if it would even make it up there in the first place!
   / Would these claimed weights be legal behind this truck? (Ram 3500) #6
I doubt you'd even see Madawaska on the way through! Before they added the passing lane, there were times we'd get stuck behind logging trucks that we didn't think would make it up it.
There has been more than a few trucks burn on that hill over the years.
I have another question now:
I've been looking at a few different ford f550's 2010 to 2013, most are advertised with a 19500 gvw.
I'd like to set one up with a hooklift and removable 5th wheel (saw one done like this, it was pretty slick)
From what I can gather from reading online,
heres one place http://www.ford.com/resources/ford/general/pdf/towingguides/12FLRVTT_SuperDtyCCjul1.pdf
if I have the right f550 and trailer combo I may be good for around 26000 lbs gross trailer weight. That should be enough to move my backhoe.
I have no idea if that would be legal in Ontario tho. I'm tiring to read up on the Ontario registration laws but it's not totally clear to me...
   / Would these claimed weights be legal behind this truck? (Ram 3500) #8
I wonder if he mixed up lbs and kg.
He says that the trailer can handle "15 tonne", that would be 30,000# or 33,000# on the deck (which would be about right for a trailer with 2 12k axles and a lot of pin weight) and 24,500# would be about right for a registered trailer weight.
I don't think that that combo could handle 53,000# without breaking...
Aaron Z
   / Would these claimed weights be legal behind this truck? (Ram 3500) #9
Welcome, I wouldn't want to have to stop that load coming down a hill with the road conditions in Northern Ontario you might end up in the Ottawa River especially this time of year!!!
PS My grandfather was born in Killaleo
   / Would these claimed weights be legal behind this truck? (Ram 3500) #10
There's no way. Licensed for 24,000 lbs... is possible. The strongest black trailers I've seen are rated for ~ 10 ton and looking at that particular unit, it doesn't even have a deep I-beam under it.
But you can register your truck for whatever you want... sooo...
2011 Jeep Wrangler (A51694)
2011 Jeep Wrangler...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53472)
2006 Magnolia Dry...
JOHM DEERE 1600 WAM LOT IDENTIFIER 113 (A53084)
JOHM DEERE 1600...
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
UNUSED FUTURE J5T TON 36" HYD THUMB CLAMP (A51248)
UNUSED FUTURE J5T...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
