would like to learn to grind and sell grain
   / would like to learn to grind and sell grain #1
corkyhughes
Coeur d'Alene, ID
john deer
My son and I are looking to start grinding and selling grain, specifically grain for chickens, ducks, and pigs. A gentleman in Washington got his recepie from the University of Washington, AG dept, but won't share it. We are looking for the ratios of grain and what type of grinder to buy. To start with we are thinking a smaller one as our production won't be large at first. Any ideas?
   / would like to learn to grind and sell grain #3
Welcome to TBN. :)
   / would like to learn to grind and sell grain #4
It may be advisable to contact a University Agricultural Dept. just to see what information you can get.
It may also get a little more complicated as different folks may want different mixes.
Then there is feed stock/finished product handling equipment.
A lot more than just grinding grain involved.:)
   / would like to learn to grind and sell grain #7
Any University Ag Department has information on feed rations.
Custom mixers will combine what the buyer wants in bulk.
Look at the tag on any feed sack in a farm store. That will give you an idea.
Here's the rub. You have to buy enough varietys of grain or supplements to mix. Storage, handling and mixing and storage of finished stock takes up room and it can be dangerous.
A small custom mix operation burned to the ground about four years ago. Dust in a motor that wasn't sealed sparked and destroyed the whole thing. No insurance.
thanks for the reply. We have some small production guys locally doing what we want to do. Scott has a business that supports him and also has a lot of animals he needs to feed. This will be a buisness that grows slow and supplies food for his animals. We are looking for a small PTO driven grinder to start with. The larger grinders seem to have a hard time controling the grind so it doesn't make powder out of it. Thanks for the tip on fire danger.
   / would like to learn to grind and sell grain #9
WELCOME to TBN :)
I moved your thread to the Ag Tractors & Machinery Forum.
   / would like to learn to grind and sell grain #10
I suspect that the gentleman obtained his "recipe" from Washington State University, the land-grant in the state of Washington. You could try contacting the Animal Science Department there for assistance: WSU Animal Sciences - Home
If you want to improve your chances in conducting your own Google searches, use the terms "balanced rations" and "least-cost rations."
You will find that there are innumerable ingredient combinations that can provide a "balanced ration" in terms of meeting an animal's nutritional requirements, but you are interested in determining the combination that does so at "least cost." That least-cost combination is obtained by application of a mathematical (usually linear) programming algorithm. Because the least-cost combination is determined by relative ingredient prices that frequently change, the "recipe" you referred to may be a balanced ration, but is unlikely to be a least-cost ration.
Steve
Edit: I just noticed that you are located in Idaho. Here's a link to the Animal Science Department at the U. of Idaho: http://www.uidaho.edu/cals/avs
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
Light Tower (A52377)
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
3 BATTERY CHARGERS (A53843)
3 BATTERY CHARGERS...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
