Would like honest suggestions about tow vehicle issues
   / Would like honest suggestions about tow vehicle issues #131
ok, I didnt read all 13 pages so this may have already been covered...
Many of the Fords are great for your needs, IF it were me, I would look at the 6.4L Fords only. When you buy, either buy an extended warranaty or immediately spend the money for a complete delete system and you will have a very reliable truck.
Seems like on the GM offereings, the pre 08 engines are bext, EXCEPT for the 02-04 LB7 engines, steer clear of the LB7s.
On the Dodges, its almost impossible to find a clean 5.9L that isnt heavily modified or has 250K+ miles. The low mileage unmolested ones are fetching 30K+. The 6.7L Cummins is also a good offering, but the early ones, 07.5-08 models really needed to be "deleted" as well. After 08, the refinements were made and its now a great platform.
If you do not require a 4X4, the options and price open up significantly, especially with the Dodge.
Poorman
You pretty well summed up most of the suggestions, but I have to ask what the "delete" is? If referring to smog equip, CA (where I live) does do smog checks, and I think they basically look to make sure all the cra is still in place. No tail pipe tests yet! So if "deleting" is removing that, I would be SOL.
I have done some reading on the 6.4 and its pretty impressive, except for the smog crap. Thanks for the feedback.
   / Would like honest suggestions about tow vehicle issues #133
In that case, if you find a 6.4L Ford that you are interested in, just make sure it hasnt been modded, and just buy a good extended waranty that will cover the more common issues associated with that engine series.
Did any of the 6.4s have the DEF? If so, what year did that start?
   / Would like honest suggestions about tow vehicle issues #135
They all had DEF. The 6.0 did not meet emissions so the 6.4 wit DEF was the short term answer.
Chris
   / Would like honest suggestions about tow vehicle issues #136
DPF?
The 6.7 has Diesel Emissions Fluid, but the 6.4 did not.
   / Would like honest suggestions about tow vehicle issues #137
DPF?
Sorry you are right. DPF. Diesel particulate filter.
Chris
Oh the DPF I can live with, in one condition or another, but I want to avoid the DEF. Thats another expense and PITA I can avoid.
Too bad about the 6.0s. Forund a nice looking 07 on CL for under 9k, with under 100k on it. The seller might not be telling the whole story either :thumbsup:.
Am on vacation in Ohio, at my sisters market, and one of the young ladies here proudly informed me she drives a 97 with the 12v Cummins. Word gets around I guess. There's one old timer here that has one with over 800K on it and wont sell till its over a million, he says.
   / Would like honest suggestions about tow vehicle issues #139
yeah... the5.9l cummins of all years have a loyal following. There are some relatively low mileage 2wd Cummins in Texas. For a CR with about 100K, expect to pay between 14-18K depending on options.
   / Would like honest suggestions about tow vehicle issues #140
I have to add DEF to my '12 F-450 about every 4,000 miles. Depends on how much you are towing, heavy on the throttle, more DEF. When my DEF monitor shows below a 1/2, I add one 2.5 gallon jug of DEF and it fills it up. Not a problem. Since the 6.7 runs so good and has so much power, I'm not going to worry about removing emissions equipment. If you intend on keeping one a long time, it may pay to buy the longest extended warranty since these are very complicated engines. That goes for any of the manufacturers.
P&H OMEGA 20-20 (A50854)
P&H OMEGA 20-20...
1996 Eager Beaver 44ft. 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
2025 LandHonor LHR-EW20000 20,000lb Electric Cable Winch (A49461)
2025 LandHonor...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
2004 VERMEER BC1000 BRUSH CHIPPER (A50854)
2004 VERMEER...
