Would I be happier with a B series?
   / Would I be happier with a B series? #1
dodge man
Super Star Member
West central Illinois
JD 2025R
So I've owned a BX2350 for a little over 10 years and have 760 hours on it. It does what I want but I often wish when I'm doing end loader work that it had a bigger bucket. I also feel the front tires are too small at times. I mow with it about half the time and have some side hills that push my comfort level on the BX but it gets the job done. I'd go with a 60" mid mount deck on the B. The other half of the hours I'm moving dirt, gravel, and snow. My driveway is paved and about 600 feet long. Sometimes we get a lot of snow, sometimes almost none. I also would like the better road speed of a B tractor.
Would one of the smaller B tractors, I'm thinking either 23 or 26 horse increase the bucket size enough that I would notice the difference? I couldn't find the specs on bucket capacity. Would it seem too big when it comes to mowing? It doesn't look like the turning radius is that much bigger but they spec that while using the brakes to make it turn tighter on the B tractors. With loaded tires would it seem as stable on the hills as a BX? I'd like to get into a used B for 5k with a trade in on my BX but I don't know if that's possible or not. Thanks in advance for the answers.
   / Would I be happier with a B series? #2
I mowed with a B2910, 60" mmm for several years. It did a better job mowing and was more stable than my JD2210 which is comparable to your BX.
There's considerable difference between a BX and a B. I think with an FEL a B would work circles around a BX.
   / Would I be happier with a B series? #3
^^^^^What he said. My first Kubota was a BX2660 (2012 @ about 500 hrs) which did everything that I asked. In fact, never having had such a machine, I was amazed at what it could do....without any performance/manufacturing defects.
Yet, I was frustrated when doing maintenance under the tractor because it sat so low...and worried about its low clearance in the woods. Having the money, I traded at a good price to go up to a B2620 (2012) and now also own a B2650(2018), which is even better at everything. If you can afford it, do it.
Cheers,
Mike
   / Would I be happier with a B series? #4
BX lift capacity is 518 full height, 990 breakout, capacity 0.18 cu yds
B2601 lift capacity is 1520 full height and 2146 breakout, capacity .3 cy yds for the Light Material bucket...so about a 50% increase. However this is the LM, not designed for dirt of heavier.
BX2350 weight 1332lbs
BX2601 weight 1622lbs
Considerable differences in FEL lift capacity, not so much in overall weight.
Keep in mind with a B2601 you are HIGHER off the ground, so you will probably need spacers to lower the COG. If you are worried about tipping, getting a tractor with a higher COG isn't the best way to address the issue outright.
   / Would I be happier with a B series? #5
Probably.
The B series, aside from the B3350SU, has position control. Not having position control is a show stopper for me.
I've been mowing my lawn and plowing snow with a B1750HSD since I bought it new in May of 1993. The 1750 is simply the best significant purchase that I have made in my 69 years of life.
SDT
   / Would I be happier with a B series? #6
I wish I would have purchased a B2601 instead of my BX2370. Realized it at about an hour on the clock.
As I recall, the B2601 was around ~$2K more initially, but would have been more like $4K to trade up from the BX with 1hr.
That said, I'm AMAZED how much happier I am with the BX since I added ballast. Beet juice, wheel weights, and a land plane hanging off the back.
   / Would I be happier with a B series? #7
B2601 lift capacity is 1520 full height and 2146 breakout, capacity .3 cy yds for the Light Material bucket...so about a 50% increase. However this is the Light Materials Bucket which is not designed for dirt of heavier.
If you are worried about tipping, getting a tractor with a higher COG isn't the best way to address the issue.
From personal experience it takes a 50% increase in bare tractor weight before you notice an increase in tractor capability.
Light Materials Bucket good for snow but if filled with earth the Loader hydraulics may not lift it, certainly will not lift filled Light Materials Bucket very high.
For a 600' driveway a plow is the primary tool to consider.
VIDEOS (3): Snow Attachments, and their pro's and con's. Snow Blower, Push Box, Snow Blade. - YouTube
Kubota BX Series VS. B Series - YouTube
So you want to TRADE UP for a new Tractor? - TMT - YouTube
How much FEL counterbalance weight in the form of filled rear tires, wheel weights and/or a Three Point Hitch mounted implement do you use during Loader work?
   / Would I be happier with a B series? #8
Sounds to me like you could use a smaller skid steer in addition to your existing BX. If you have a regular diet of dirt work, then a SS is the better tool for the job than any tractor.
I am not going to get a skid steer. To expensive although I would love to have one. A couple things prompted me to start this thread.
One is a lot of snow. The rear blade works great for small snows but I use the FELfor deeper snows. Some winters I hardly move any snow. I drove the tractor into town this last weekend and the road speed of the BX is pretty bad.
I also had a creek cutting into my yard so I have been dumping rock over the edge. The bigger bucket would be nice. I would let the creek do its thing but long term I am concerned about it getting close to the house.
   / Would I be happier with a B series? #10
I've done this trade several times. The BX is a better mower but it's a smaller tractor than the B series in every way. I've actually written several comparison posts between them sitting side by side and another old poster also did a comparison piece as he traded and then traded back.
Higher seat off the ground feels like your higher off the ground and is a little more unnerving.
I originally bought a BX2200 MMM FEL 15 years ago as my first tractor. I was on new hillside rocky gullied treed land and kept going more and more into FEL tractoring while also mowing. After a year I decided I wanted to go more into excavating but ground clearance on the BX limited me, actually got it stuck on top of a big brush pile once and had to have my real dozer excavator get it down/off when he came back to do more leveling/tree clearing.
I traded my BX2200 MMM FEL to a B7800 RFM FEL and a BX1500 MMM and stayed with that combo for a history breaking for me three years with awesome results and work accomplishments. I messed up and traded the B7800 to a L3240 FEL and it had a seat so high off the ground I wouldn't use it on my mostly hillside landscape work areas so rapidly traded it to a B3200 FEL and that BX1500 MMM kept on mowing the steep areas while I used the 6' RFM for the flatter front yard.
I traded for a skid steer a couple of years ago and that was my biggest mistake ever, lost $6000 in less than a year on that mistake. It would slide sideways down my hillside in the snow and get stuck and had to wait till the snow melted to ever get it out. Skid steers are construction/landscaping equipment and for mostly level ground or straight up and down excavating work in my opinion and personal handson experience and they are one of those rent by the day machines.
Find some of the older B vs BX comparison posts and see more opinions by those of us that have done it or ask specific questions here. I like the 3 speed over the 2 speed. The B26xx is a nice machine and sure Barlows would give you a trade price for your BX.
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52128)
2020 New Holland...
2015 INTERNATIONAL PROSTAR 122 SLEEPER (A51219)
2015 INTERNATIONAL...
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A52128)
2023 PJ 49FT...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2018 East Texas 20ft Utility Trailer (A49461)
2018 East Texas...
