Would an angle blade be better than box blade for this?
   / Would an angle blade be better than box blade for this? #1
East TX
Mahindra 2555 HST
When we had our place re-planted in pine this spring, they cut firebreaks for a controlled burn. I want to keep them as trails, but a couple are on a significant sidehill in parts. I used my box blade, with the blade tilted on one side to make them more level to drive on and keep mowed. It was working ok, but of course, being a box blade, it fills with dirt, mostly on one side. Ive never used an angle blade, but i was thinking it would do a better job of moving the dirt from the side of the hill being cut into to the other side to fill it in. Im hoping that make sense. I guess my concern/question is will a box blade cut into the dirt well? Its east texas red dirt. Which is really dry right now
   / Would an angle blade be better than box blade for this? #2
How well a rear blade cuts depends a whole lot on its weight. I have a heavy rear blade and it cuts into virgin soil well. But this is a 1000+ pound rear blade behind a tractor weighing 10,000+ pounds.
If you can find a heavy enough rear blade - it will do what you want. You might need to loosen the soil first so the rear blade can perform better.
I have a roll over box blade with scarifiers. I can use it to chew up the dirt and grade. It's not as good or fast as the rear blade but it will get the job done.
Your Mahindra should be able to pull a fairly heavy implement.
   / Would an angle blade be better than box blade for this? #3
Kind of hard to describe but a blade that tilts might work well for you. That way you can angle it to get a corner to dig in and level the area.
my box blade can tilt by adjusting the lower 3pt arms on the tractor. My thinking was that doing that, and having an angled blade would work better than just a tilted box blade. I dont know what my box blade weighs, but its a HD 6' so 5-600lbs? From what it looks like, most of the 6' angle/scrapers are 3-400lbs. I want to make the trails about 6-8' wide and id guess theres probably an 18"ish difference from the high side to the low side of the trail that id like to level out
   / Would an angle blade be better than box blade for this? #5
A box blade can do it but a blade can cut and disperse it mush faster. Also, a blade will cut ditches far better. You'll want a small ditch on the uphill side of the trail your building.
   / Would an angle blade be better than box blade for this? #6
I would say that yes a rear blade "could" do a better job.
If it is a heavy blade with hydraulic tilt.
Unless your side slope is the same you need the hydraulic tilt to be able to adjust the angle as you are working.
With the blade tilted down on the high side and angled with the low side forward,
it would cut and roll the dirt to the low side.
Then when your trail is leveled out, more tilt and angle the same way will created a ditch on the high side.
Also when ran in this mode the full weight of the blade is concentrated on the portion doing the digging.
It will also turn your tractor into the cut side if it catches and hangs.
   / Would an angle blade be better than box blade for this? #7
Personally I am looking for a scraper blade with both tilt and angle as my condition change as to where I am grading. If I am cutting into a slope to create a "level" trail. tilt is most important to me in a blade... Conceptually to me a box blade can only cut on same angle as tractor (no tilt option unless screwing endlessly with hitch) ....
   / Would an angle blade be better than box blade for this? #8
Road graders don't use box blades.
   / Would an angle blade be better than box blade for this? #9
I had to ballast the end of the angle blade that I wanted to cut into this well-compacted gravel. Tilting the 3-point linkage (see photo) didn't provide any down force at all.
The builder tag on this ancient blade says 'Carrington Terracer' and online literature shows it cutting into the uphill side, but that must assume working plowed ground.
I have three more wheel weights I could add for more ballast. I'm thinking about welding 'ears' at the outer corners of the blade assembly to hang the weights on.
img-20210322-01rbackbladeinlane-jpg.699999
   / Would an angle blade be better than box blade for this? #10
A rear blade will move dirt from one side to another good. For real dirt work you really need a very heavy rear blade. The ones with a more flat blade like the sell at tractor supply are really only good for snow. Dirt work where you can encounter roots I would look for nearly a cat2 blade for a cat1 tractor. At minimum would be 600lbs.
LOT LOCATIONS (A51222)
3014 (A50657)
3014 (A50657)
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50774)
UPDATED INTERNET...
71067 (A49346)
71067 (A49346)
CAT 420F2 IT (A50854)
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
