Front-End Loader Worst things to do to a FEL
   / Worst things to do to a FEL #51
Thinking back, most of the times I almost damaged my FEL was when I wasn't using it. Unless you need it at least take the bucket off, it prevents collisions with trees, telephone poles etc... when you are watching what is attached to the back of your tactor. My avatar shows I don't follow my own advice :) Good Luck!
   / Worst things to do to a FEL #52
In theory yes. The long arms of a tractor FEL are far more vulnerable than the short stubby arms of a bulldozer or the spring protected arms of a pickup truck plow. Still there are not too many damage reports which is probably because most snowplowing with CUTs is done on known asphalt surfaces with little risk of a high energy collision with a sewer cover or curb etc. No doubt though, a CUT FEL would be much more easily bent in such an impact.
That is why I recommend trip springs on the plow.
I've been plowing snow with a 7' snow blade on the loader for years. Never had a problem yet.
I hit stuff all the time. With the trip springs on the plow it just flips down and snaps back before it causes any damage to the loader arms.
   / Worst things to do to a FEL #53
Ya, my new snow plow has trip springs also. A whole heck of alot of people here have them, and i have not heard of any bent arm problems from anyone. They all love them for 6-8" days (our usual daily snow fall).
   / Worst things to do to a FEL #54
Put the bucket down on the highway.
No clue where that pic came from or if it is legit.
   / Worst things to do to a FEL #57
Y'all beat me to the punch. When I saw the post the first things that came to mind were:
- don't forget you were toting your chainsaw, chains, chain binders, etc. in the bucket when you decide to move a pile of dirt from here to there.
- don't road your tractor with your bucket tipped down anything below level - as witnessed by the broken tractor in the previous pics
- don't lift your bucket to the top and put your extension ladder in it to get that last bit of height needed when putting up your Christmas lights.
   / Worst things to do to a FEL #58
2 NO NOs when using fel, First,. dont carry the bucket around raised high without using extreem caution, Second,.. Dont ram anything on one side of the bucket, causing twist in the main frame, Or the bucket,. When opperating Heavy Equipment,.Using your head is probably the most important rule you need to abide by, And caution should always be # 1,.. As far as back blading,? Front end loaders were designed to be used at 90 degrees plus, Common sense applies here a well, If you understand the limits of your equipment, and dont ram rod it, you can get alot done without, twisting/bending things :thumbsup: Eric
   / Worst things to do to a FEL #59
Scrooge!
   / Worst things to do to a FEL #60
The proper way to do it is to throw a rope over the roof, tie it to the bumper of your wife's car, use the rope to help pull yourself to the peak, and than as you finish with that last light clip have her get in the car and drive off. The video your kids take of this will go viral on Youtube and you will be an instant hit, either from being a star or the impact when you contact the ground.
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
2014 Chevrolet Traverse 2LT SUV (A55853)
2014 Chevrolet...
Cushman Cart (A55853)
Enmark Z Spray (A53316)
Enmark Z Spray...
2007 OVERLAND  TANK TRAILER (A53843)
2007 OVERLAND...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
