LD1
Epic Contributor
Yep. Making the drawbar available is one of the best reasons for using a dedicated weight box on the 3pt instead of depending on a bulky implement. One of these days I might even get around to building one.
I have a concrete weight, but it isnt big enough. It is roughly ~500lbs. That with loaded tires the loader can still overcome the weight.
I would need closer to 1300 or so lbs to do what my blade (700+lbs) or my 6' cutter(1000+lbs) can do for ballast since those two place the weight much farther back.
Plus I like changing implements as little as possible. So When I dig out a stump, I like already having the blade on so I dont have to change back out when I go to backfill and grade over the area.
Call me lazy if ya want, I call it making the best use of my time. And I know the risks, and like I said, if something breaks, I've go no one to blame but myself. I will fix it and life goes on.
