Worst stuck pics
/ Worst stuck pics #41
A couple of mine. Couple out of 100s. If you know how big a Unimog is you will get an idea how deep it was. Needless to say the modified air box was just touching the water. I am reaching for the electric winch cable. I triple lined to get out of this one.
/ Worst stuck pics #42
Just a few of my escapades
/ Worst stuck pics #43
Did the case pull it out?
/ Worst stuck pics #44
Actually the Case did pull it out. I didn't think it would but it actual came out pretty easily.
/ Worst stuck pics #45
/ Worst stuck pics #46
It seems that way at times. That's what I get for trying to dig a pond in the cattails. The little dozer didn't even grunt pulling the maintainer out.
/ Worst stuck pics #47
Not the worst for sure, but enough to really play havoc with a tight schedule.
EDIT: I have a 4 or 5" cylinder with a good 4 feet or maybe a little more stroke with shackles on each end. I just plug it into the closest remotes. Got it free from a friend. It probably came off some large construction equipment. I have used this to extricate myself many times, especially when alone. Sometimes it's only a matter of moving a couple of feet or so. You have perfect control over the pull, there is no jerking or breakage (except the occassional crappy chain), you don't dig up the area with the towing machine and the forces exerted are immense!
/ Worst stuck pics #48
Slid off of a driveway I was trying to plow and could not get back up onto the blacktop. I was able to get alongside of it before I finally slid into this tree. Neighbor across the street came by with a John Deere 4000 series with front loader and tiller on back for weight. He was not able to pull me out nor was a older F1 50 4 x 4. Had to go home to get my bobcat CT 225 and was able to pop it right out with that.
/ Worst stuck pics #49
Here's mine... Cost $200 to get out via wrecker
/ Worst stuck pics #50
These arn't my machines but I hired these guys and brought in the rock truck hoping to get a jump on spring. I like to think I helped at least bit to extricate this big TOY! Shortly after, we just called it a day!
/ Worst stuck pics #52
Amazingly enough she is still with me after 30 years of this type of stuff. :cool2:
/ Worst stuck pics #53
My oldest boy used him younger brothers bike. I came back on a trailer.
/ Worst stuck pics #54
Worst stuck to date last weekend using my case 430 with steel over tracks around my personal property....
/ Worst stuck pics #55
I'm guessing that used to be one fine looking machine! That looks like the kind of quick sand I used to see in the movies as a kid.
/ Worst stuck pics #56
Did you get it out??
/ Worst stuck pics #58
That looks like the type of super-wet mucky clay we have around springs here when you dig down some.
/ Worst stuck pics
That sucks ! Water in the engine compartment ? What did it take to get it out ?
/ Worst stuck pics #60
My worst stuck was back when I was farming. There was a big storm coming and I had round bales of hay on the low ground by the river. They wee calling for a big flood so I went down to get them. I had the last bale on the loader on my 255 massey when the grass broke. When I broke through the grass it sat on the rear end and spun with water running off of the tires. You could turn the rear tires by hand. It did not look that impressive but I knew that the tractor would be under water before sunup. I got a friend with a skidder that had a wench on it to pull me out. Best $100 I ever spent.
Hercules Gun Safe Holds 20 Guns (A65583)
Hercules Gun Safe...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
2005 Ford F250 XLT Super Duty (A66408)
2005 Ford F250 XLT...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
International 1486 Tractor (A66285)
International 1486...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
