Worried about freezer
   / Worried about freezer #11
For under 20 bucks, you can get a Kil-a-Watt meter and see exactly how much power your freezer is using. Good for checking other things in the household too.
Amazon.com: kill-a-watt meter
Then go to the Energy Star website and compare the amount of power your current dog uses compared to a new ES rated model of the same size. Most of the 20 cf models seem to run in the 480kw/hr per year range. THEN you can make an informed decision on replacement. We replaced our mid 90's model side-by-side fridge few years back (1200 KwHr/yr) with a larger, nicer, french door, ES model that uses under 400kwhrs/yr. Amazing the difference foam insulation makes over the old fiberglass insulated models.....plus LED lights, more efficient compressors, etc.
ENERGY STAR Certified Residential Freezers | EPA ENERGY STAR
We have 7 freezers here + an older 17cf upright I keep for a spare in case one goes, or we turn on when freezing a lot of fresh meat (like a whole cow) at one time....let's us spread the meat out to freeze quick. 6 of the 7 are smaller chest freezers....7-9cf range. We raise most of our own food...all the pork, beef, chicken, catfish + a lot of veggies and fruits. We'll go into fall with all full, then condense down the stuff and gradually turn one and another off. I like having our food spread out over several smaller ones (easier to find stuff) and less likely to suffer a lot if one goes out (and still have that old upright for a spare).
All our have temperature monitor/alarms on them. 14 degrees IS way high for a freezer....our average is a 3-5 degrees below zero.
Part of 'freezer row':
enhance
Key to having freezers is inventory control. Wife does an EXCELLENT job of it with a list on each, updated when stuff enters or leaves.
enhance
Thermometer/alarm:
enhance
   / Worried about freezer #12
Take a look at the scratch and dent section of Best Buy, Lowe's or wherever. I picked up a $600 upright for $250 because of a slight crease in one side and no handle, delivery included. When it was delivered, the driver noticed the missing handle and said he would order one...got it in a week!
   / Worried about freezer #13
Our lowes has a floor model 18 cf upright freezer for 319.00. I got my last 20 cf upright a few years ago for about 250 new. I see the prices have went up a bit
Sears has a 20.9 c.f. not frost free Kenmore on sale for $467 online only. It is the same thing as the Frigidaire we looked at in Lowes today. It was $673 there. HomeDepot has it for $733. Best Buy for over $800. Guess I will be giving Sears some business.
   / Worried about freezer #15
Okay, I'll be the blunt one:)....stick a crowbar in your wallet and buy a new one. The upright has worked for 40 years, it deserves a retirement. There are lots of young, eager uprights looking for a job.:laughing:
WELL.....K...M...A...
Ordered the Kenmore online for $200+ less than the same thing at Lowes and HomeDepot. They will deliver it next Monday. Then I walked by the remote temperature thingy and the temp had dropped to -7F. It has dropped 21 degrees since this morning.
When we defrosted/cleaned Monday we had everything in coolers and put it right back in. It stayed at 14 for two days. Then suddenly dropped 21 degrees in about six to eight hours. There is definitely something wrong.
Glad the new one is coming.
Also TnAndy I ordered the Kil-A-Watt meter just to check it out. We junked my mothers huge chest type last summer and I wish I had owned one of those meters then. It was over fifty years old and frozen solid the last foot or so. We had to stand on a step ladder to reach the bottom. I remember when dad bought it he got the biggest they had. I bet it was costing her a dollar a day to run.
RSKY
   / Worried about freezer #17
I got a really old freezer, was wifes grandmother, maybe from 50's. It just keeps on working
I need one of those alarm thermometers.
   / Worried about freezer #18
This is the correct answer but for a different reason.
Any good serviceman will tell you that as the temperature around a refrigerator or upright freezer gets colder, the higher the temperature inside will be. The chest type will continue to maintain the cold temperature because it was made to be used outside. You can purchase refrigerators and upright freezers that will work in the cold, but they cost a lot more.
I have a project that would benefit beyond imagination from this. Will you explain the science behind this?
   / Worried about freezer #19
We bought a 2nd fridge several yrs ago, put it in the garage. Lost everything in the freezer because it shut down when the garage got cold. Had a repair guy come, first thing he told me it wont work in cold temps. Moved it to basement, no problems.
If you want one in a cold area, they make them, just make sure before you buy.
   / Worried about freezer #20
Reasons most older units and a few newer one's work and most newer one's don't has to do with type condenser(coil with cooling fan/coil welded to jacket/pipe web on exterior rear wall) how/where metering,return and comp to cond tubes are mounted. Warmer ambient temperature equal's higher pressure,cooler ambient equal's lower pressure. More refergerant remains liquid as pressure drop's. Pressures drop much faster and lower with fan over coil. Low pressure result's in liquid returning to compressor from evaporator. Same as a hydrolocked tractor engine,liquid can't be compressed so motor stall's. Combination of passive air over pipe web along with carful line mounting can control liquid reaching compressor. For the benefit of tinkers,retrofitting any condenser configuration with an oversize receiver alow's operation across a wider ambient temperature range. Your cab tractor and family car face the same challenge because of variable compressor speed as engine rpms increase/decrease. That's why that 2 liter size receiver will be found on tractor-car-truck air conditioners. I realize that might be boring to some but everyone can carry something away from it,don't spray cold water on a condenser while compressor is running. It can damage the compressor.
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2015 Chevrolet Silverado 1500 Pickup Truck (A53422)
2015 Chevrolet...
New Quick Attach Hay Spear (A54865)
New Quick Attach...
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
1999 VaXcavator VT500D Towable Vacuum Trailer (A55851)
1999 VaXcavator...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
