Worn pins
/ Worn pins #1
Alan7s
Sharon, CT
Terramite T5C
Well we finally got the swing cylinders off; had to take the axle off and drive them out. One cylinder rebuilt; the other on order.
A couple of the pins on the boom are pretty worn; from what I've seen, I'd expect them to be pricey from the company. Are these
obtainable elsewhere? I suppose those end brackets that hold the pins in place would have to be welded on, or can the whole thing
be bought as is? Anybody have any idea what I should expect to pay?
Thanks
/ Worn pins #2
I bought a new pin for the boom on mine last year. If I remember correctly it was around $75.00 with shipping and handling. The shipping and handling charge was $22.00 I read that terramite has dropped the handling charge now so they should be a little cheaper. The pins are hardened Steel so that makes them pricey.
/ Worn pins #3
I'm replacing a bucket pin on the T5C with what's commonly referred to as 'stress-proof' steel, and what my supplier says is the most popular for this sort of thing nowadays. I guess the finishing process includes a final forming that renders the surface smooth, slightly hard, and uniform size/roundness. (like DOM tubing?) It machines well, but I'm told it doesn't weld for sour hen crap, so I'm ready to thread/tap the pin & bolt on a new end tab to hold it in place.
The usual 'caution' when selecting an alloy for this is that if a pin is of 'harder' mat'l that its bore(s) eventual wear will be on what's more difficult to deal with :eek: (rebore & bush vs using 'sacrificial' wear components). Perhaps your metal supplier will also give you a recommendation based on recent traffic. (Always good to chat-up the guys beyond just what size is needed. ;)) My SP bar is 1 1/4" x 9", feels as smooth as TGP, and was was <$20 IIRC. Good luck! .. and let us know what you come up with.
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63688)
2023 Kubota L3560...
Caterpillar Traxcavator service manuals (A63117)
Caterpillar...
2015 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2015 HINO 268 4X2...
2025 70in Rock Bucket Skid Steer Attachment (A61572)
2025 70in Rock...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
John Deere Hubs and Spacers (A64119)
John Deere Hubs...
