Worn governor on '63 Ford 4000
   / Worn governor on '63 Ford 4000 #1
Old Virginia Joe
SE Va.
'63 Ford 4000, '48 Massey Harris 30
A year after my engine re-build on this '63 Ford 4000, it started surging the engine, and after many tries at finding the reason, the local tractor shop told me my governor was messed up. They pulled it down and found the weights are worn with flat spots, and so we've been trying to replace the governor assembly. The shop ordered the part and the inside hole diameter of the governor assembly that slides on the crankshaft past the splines is too big, too loose, too sloppy a fit. So he ordered another one, and it was the same. He has thrown up his hands, so I ordered one from my favorite parts catalog. It came in and is also too loose! The packaging is not the same style at all on the two products, so I believe they are different manufacturers. The mechanic is about 40 years or more into his career and is now the shop manager. He says, "Joe, I'm telling you my gut tells me not to put this loose thing on your tractor and button it up, cause I'm not confident it will work right after we do all the labor to put you back together." He showed me how nice a fit the old one is, compared to two of the new ones. Does anyone here have experience with this specific issue? Please advise. The old opening was 1.241 inches and the new one is 1.304, too loose. I do trust this mechanic. He's no kid and is well respected. Thank you all!
   / Worn governor on '63 Ford 4000 #2
Any way to build up the new one and machine to correct size?
2014 Caterpillar 289D High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2014 Caterpillar...
2017 Ford Explorer SUV (A51694)
2017 Ford Explorer...
UNUSED FUTURE 20' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 20'...
JOHN DEERE 2038R LOT IDENTIFIER 162 (A53084)
JOHN DEERE 2038R...
2018 GMC 2500 4x4 Crew Cab (A52384)
2018 GMC 2500 4x4...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
