Worn governor on '63 Ford 4000
   / Worn governor on '63 Ford 4000 #1
Old Virginia Joe
Bronze Member
SE Va.
'63 Ford 4000, '48 Massey Harris 30
A year after my engine re-build on this '63 Ford 4000, it started surging the engine, and after many tries at finding the reason, the local tractor shop told me my governor was messed up. They pulled it down and found the weights are worn with flat spots, and so we've been trying to replace the governor assembly. The shop ordered the part and the inside hole diameter of the governor assembly that slides on the crankshaft past the splines is too big, too loose, too sloppy a fit. So he ordered another one, and it was the same. He has thrown up his hands, so I ordered one from my favorite parts catalog. It came in and is also too loose! The packaging is not the same style at all on the two products, so I believe they are different manufacturers. The mechanic is about 40 years or more into his career and is now the shop manager. He says, "Joe, I'm telling you my gut tells me not to put this loose thing on your tractor and button it up, cause I'm not confident it will work right after we do all the labor to put you back together." He showed me how nice a fit the old one is, compared to two of the new ones. Does anyone here have experience with this specific issue? Please advise. The old opening was 1.241 inches and the new one is 1.304, too loose. I do trust this mechanic. He's no kid and is well respected. Thank you all!
   / Worn governor on '63 Ford 4000 #2
Any way to build up the new one and machine to correct size?
2025 INDUSTRIAS AMERICA 7014 70"X14' HYD DUMP TRL (A51247)
2025 INDUSTRIAS...
2023 JOHN DEERE 8R370 LOT IDENTIFIER 204 (A53084)
2023 JOHN DEERE...
2010 Ford Crown Victoria (A51694)
2010 Ford Crown...
2022 KUBOTA SSV75 SKID STEER (A51246)
2022 KUBOTA SSV75...
80in HD Tooth Bucket with Side Cutters (A53472)
80in HD Tooth...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
