Workmaster 75 fuel gauge problem
   / Workmaster 75 fuel gauge problem #1
budlite
Toney, Alabama
NH Workmaster 75
Got an error code 14052, ground fault error on fuel level sensor. Can't find the darn thing. Downloaded a $20 WM75 repair manual but it's for prior models. Anyone know of a source good for a 2019-20 WM75 manual? Dealer wants in excess of $500 for a hardcopy.
   / Workmaster 75 fuel gauge problem #2
Are you saying you can't find the fuel level sensor? If it doesn't screw into the tank from the top then it is very likely part of the fuel pump assembly. My S x S is like that.
   / Workmaster 75 fuel gauge problem #3
From the parts illustration on messicks site it looks like fuel level sensor is in a recess area on top of your fuel tank to the right of your fuel cap on inboard side of tank. Hope that helps you find it so you can check the wiring harness.
Thanks Rusty A I was able to find the sensor location thanks to your help. Got a broken wire, have to remove tank to be able to fix, so I guess I will just keep it filled instead of relying on fuel gauge.
   / Workmaster 75 fuel gauge problem #5
Glad you found the open circuit.
(12) TOPPING JARS (A58374)
(12) TOPPING JARS...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2022 Behnke Trailer (A55973)
2022 Behnke...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
Portable Restroom (A54865)
Portable Restroom...
