Workmaster 55 Help
   / Workmaster 55 Help #22
I only hear the whining noise in reverse, are you seeing the same?[/QUOTE
x2 = Whining noise is only present when I'm in reverse and in speeds 3/4 or 7/8. When backing at slower gears, the noise is not as noticeable. In forward she's quiet. I've only got about 75 hours on the tractor, and haven't noticed an increase or decrease with use.
   / Workmaster 55 Help #23
Just bought a 2014 workmaster 55 and noticed the fuel filter and cut off has two ons? Is one a bypass for the fuel filter? Also does anybody know if you can add a detent on to the standard remote hydraulics that comes with it.
Was at the dealer Friday. I ask about the on off on the filter. That filter base is also used on bigger tractors with 2 tanks. So that is the tank selector switch. I guess it's nothing we need to worry with.
Sent from my iPhone using TractorByNet
2020 Ford F250SD (A55973)
2020 Ford F250SD...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2019 Komatsu WA380-8 Wheel Loader, S/N A74991, PIN# KMTWA130VJNA74991, Turbo Diesel Engine, Komatsu (A59076)
2019 Komatsu...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
John Deere 3025E (A53317)
John Deere 3025E...
