worklights?
/ worklights?
i was looking for dc tractor lights--sorry for not being clear on that
tony
/ worklights? #12
Yep I made a boo-boo /w3tcompact/icons/blush.giffor I thought Tony wanted some work lights as in a shop.In the long run T8..277volt last longer and tad cheaper to use.In our chem labs you can see the lighting differents between T8 vs T12,the light is so much better.
/ worklights? #13
Steve,
boy, i'm really showing what a dummy i am, but can i splice into the tail lights(mine are turn signals only), or do i need to hook directly to the battery? thanks :)
/ worklights? #14
You only have turn signals? Whether turn signals or hazards you wouldnt want your work light blinking./w3tcompact/icons/frown.gif
To prevent accidentally leaving lights on and draining battery, you want to connect to switched hot wire behind dash, use test light to find.
If an aux. light was an option on tractor there might be a blank in your fuse block for that, if so fill it in with labeled size and find the new hot in bundle leading from block.
/ worklights? #15
thanks again..yep, i suppose a blinking worklight wouldn't be smart :)
i'll try the other route. sorry for the dumb questions, but i just bought this used yanmar 1401d
and i'm new to the tractor business!
tony
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A61307)
Hobart Champion 16...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
2018 Ford Fusion Hybrid Sedan (A59231)
2018 Ford Fusion...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
