Working with conduit
   / Working with conduit #1
raykos
Central Pa.
JD2305
Hi all,
Been thinking about using 1/2" EMT conduit to make a rack to attach to the ROPS of my JD2305. Don't plan on using it for anything heavy or big, so metal conduit should be strong enough; however, I'm finding that fittings are a problem...they're more expensive than I thought, plus can't find things like normal elbows & tees. So, I bought a 1/2" EMT conduit bender, and it will bend the conduit 90 degrees with a 5" radius.
But, now I'm wondering; are there any tips or tricks to bend the conduit tighter than a 5" radius? Also, if I want to make something resembling a ladder, is there a way to attach the rungs to the rails, since I can't find any conduit tees? I was thinking about using 1/2' metal pipe clamps?
Thanks,
Ray
   / Working with conduit #2
Hi all,
Thanks,
Ray
A tighter radius bender will be tough to find, as the radius allows for the electrician to fish wiring through the conduit.
As for rungs, my uncle has made a dozen ladder deer stands over the past few years, and he used his trusty wire-feed welder.
   / Working with conduit #3
There should be a minimum diameter bend for each pipe size/schedule.:)
For a ladder use larger rails, drill holes and place the smaller steps in the holes.:)
You may also be able to find some light weight weldelets. Supplier??? :confused:
   / Working with conduit #4
Egon has it on the ladder. I built a rack for an ATV that way. I bent 4 90s in 1" conduit. I drilled holes for 1/2" rungs. I pulled it apart and inserted the rungs. Then welded the two ends together. If you can't weld, a coupling woud have worked.
   / Working with conduit #7
Hi all,
Thanks,
Ray
There is another quick and easy way using 1-3/8" chain link top rail. Corner fittings are available in several styles that attach with drill bolts. Very fast with a drill/driver. Gate brace clips would let you attach cross rails and they can be secured with a drill bolt. This same method is usable to build kennel panels. I easily built 6 x 20' panels and 4 x 6' panels and held them together with corner clamps. Gates are easily built and set into the panels. The top rail comes in lengths up to 21'.
Vernon
   / Working with conduit #8
It's been a few years since I have run any conduit, but if I remember correctly we used the dia. x 9 for determining our rad. on conduit for a good pull. There are some ways that might work to tighten the radius, but if fittings can be found that would probably be the way to go.
   / Working with conduit #9
Draw it out and take it to a muffler shop for bending and swaging. If you can carry the conduit and drawing usually a $20 get everything I need done here.
2014 Dodge Avenger SE Sedan (A51694)
2014 Dodge Avenger...
2018 KENWORTH T800 (A53843)
2018 KENWORTH T800...
2007 Dodge 3500, 6.7 Cummins, Automatic (A52384)
2007 Dodge 3500...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
