jinman
Rest in Peace
- Joined
- Feb 23, 2001
- Messages
- 21,008
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
There has been a lot of discussion in this forum about hydraulic pressure and how it is set. One member, Spencer, even bought a pressure testing rig and loaned it to other members by shipping it from TBN member-to-member (although it seems to be "lost" at the moment). Lately, I've been digging/collecting/moving some b-i-g rocks with my rock bucket and FEL. These rocks are right at the maximum capability of my 16LA's lift. One of them was so heavy I had to surge the tractor forward just to get the bucket curl cylinders to lift the front of the rock slightly off the ground while I pushed/slid it to where I needed to put it.
All this made me wonder if my pressure was correctly set. I needed all the 2500 psi, and I found myself thinking it would be nice to check and make sure the pressure is correct. I have two liquid filled pressure gages and I rigged one to a quick connect fitting so I could put it on one of my remote adapters.
I installed the pressure gage into one of the rear remotes, then I started the tractor. I let the engine warm up a little and then I raised the rpm up to about 1500. I operated the remote lever and the pressure gage jumped up to 2200 psi. Then I set the engine rpm up to 2200. When I repeated the remote lever, the pressure jumped immediately to exactly 2500 psi and I could watch the exact moment the relief valve lifted to regulate the pressure. It could not have been any closer to perfect. /forums/images/graemlins/cool.gif
Since the pressure is controlled by a pressure relief valve, I suspect the temperature of the fluid will not have much effect on the regulated pressure. I was really impressed with how accurate my pressure is on my 900 hour tractor. It kinda restored my faith in the factory settings. I disconnected my pressure gage and left things exactly as they are. /forums/images/graemlins/grin.gif
