Working tire pressure = Contact area ???
   / Working tire pressure = Contact area ??? #1
rdinatal
Lake Normanopolis, NC
Old: 2016 eMax25s HST, New: 2017 Max 26xl HST
I was wondering what the thoughts are on tire pressure. It doesn't matter if they are filled, or not, or tractor weight. I'm interested about contact area. I was thinking of 80% contact on a hard surface like cement. At any time in the work day the supported weight can be plus or minus 1K lbs depending upon a laod in the FEL or 3pt. On mine at 80% contact, unloaded, the rear would be at 10psi. That seems low.
On my truck I like 90% contact to the shoulder but then the truck doesn't have as much of a weight variance in everyday use. When I want to load it I air up/down accordingly.
So, on a tractor what do you find is a good balance between ride and capacity??
-R
   / Working tire pressure = Contact area ??? #2
I run all of my tractors at max psi that is printed on the sidewall. Especially important for the front tires of a loader tractor. They never gave me a smooth ride no matter how much air they have.
   / Working tire pressure = Contact area ??? #3
Ditto for me.
   / Working tire pressure = Contact area ??? #4
I run my fronts at max psi. I run my rears so I get full ground contact.
   / Working tire pressure = Contact area ??? #5
I run mine at 45-50 psi. I think max rated pressure on mine is 45.
   / Working tire pressure = Contact area ??? #6
My loaded R4 rears I run at 15 psi, fronts at 35
   / Working tire pressure = Contact area ??? #7
Loaded rears at 18psi, fronts 20psi, up to 24 for FEL work and back down again for traction/ride comfort. Ag tires.
If you do much on pavement go 2psi lower, over inflation wears the tires out faster than under inflation as the circumference from center to sidewall has a greater difference with more pressure
   / Working tire pressure = Contact area ??? #8
It kinda depends on the type of tire and the service it is in.
   / Working tire pressure = Contact area ??? #9
10 PSI in the rears is about right for good ground contact. I would never run the rears OR fronts at or above the max rating. I only run enough pressure in the fronts so that they don't squat or roll on the rim when I have a fully loaded bucket. This is usually 10 pounds or so below max pressure.
My eMax is about 2200lbs with the loader. The dealer had the rears at 15lbs and I was noticing the contact was about 60%. With 10psi the contact increases to 80%. I really don't want to go any lower.
I need to check the front.
-R
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
Kubota Salt-Spreader (A52384)
Kubota...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
