Working rail roads and their tracks.
   / Working rail roads and their tracks. #4,251
When you think about it, a Trackmobile is just a skidsteer.... and my FEL does a lot of what the skidsteer can do...
   / Working rail roads and their tracks. #4,253
I worked as a temp one time and they had a coupler hooked to the counterweight of a large wheeled loader to move cars.
A repair yard I worked at we pushed and pulled cars with a payloader all the time.
   / Working rail roads and their tracks. #4,255
Who needs a switch engine. Just fire up the farmers helper…
. Mill in Burnett Wisconsin.View attachment 4545032
It's Peachy Bros. Elevator. They have a car mover on the other side...
   / Working rail roads and their tracks. #4,256
When I was loading Army and Postal vehicles onto rail cars, we had to move the cars by hand after the loco dropped them on the siding to get them close enough to each other for the bridge plates to span the gap between cars. Then we'd set the brakes.
The tool was similar to this....
   / Working rail roads and their tracks. #4,257
I noticed that it looks like the drawbar is a tube and a drive shaft that connects the lead truck to the tractor PTO. The wheels on that truck have chain sprockets and could be driven by the PTO for more traction.
   / Working rail roads and their tracks. #4,258
Here's one with side rods.
Bruce
   / Working rail roads and their tracks. #4,260
I'm curious what part of that they were able to get a patent for unless it's the side shift part of the design, Everything else is nothing new. There have been variations of all sorts on Speedswings and end loaders for years that have done the very same thing. The only difference is most of them hinged upon sitting on the track. However they also raised and lowered the coupler and used it as a traction aid by applying down force on the rail wheels. They often had oversized or auxiliary air compressors to handle the added air requirements. I've also saw small elevators moving cars with just a tractor and nothing more.
HOMEMADE 94"X12' DBL AXLE TRAILER (A58375)
HOMEMADE 94"X12'...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56438)
2014 Doyle Dry...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
Bush Hog Rotary Cutter Mower Attachment (A56857)
Bush Hog Rotary...
3in Poly Pipe- SOLD AS ONE LOT (A59213)
3in Poly Pipe-...
