Working rail roads and their tracks.
   / Working rail roads and their tracks. #2,231
Those heated containers are really something. Make a heck of a “shed” for farm & ranch use.
   / Working rail roads and their tracks. #2,232
In the U.S., the maximum truck weight on highways is 80,000 pounds gross weight,
Not exactly correct. Michigan is 163,000 GCCW on 11 axles. So is Ohio and Indiana on special permits on designated routes. Michigan is any road unless there is a weight restriction on that road. Back when I was trucking, I hauled many loads out of Burns Harbor and Butler Indiana as well as Toledo and points south with 80+ on the deck. Used to haul out of Weirton West Virginia with 2 coil loads too. Take s a lot of horsepower (big Cat engine) to climb the hills out of the Ohio valley up Route 11 towards Youngstown with 80 plus on the deck The outfit I worked for ran big cats turned up to maximum horsepower with 18 speed road rangers. We were set up with air dumps and mufflers on the trailers so we could get on the Ohio Turnpike loaded which was the shortest and easiest way back to our plants in Toledo and Erie, Michigan. FYI, the OTPK weight limit (legal) is 90,000 pounds GCCW which is Class 9. Those were the days and I always enjoyed hauling big heavy loads. The way our trailers were set up, we could put over 120 gross on the pike by shifting the per axle weight around using the air dumps (trailers were all air ride). Was acceptable cheating.
Never pulled an inter modal container, never wanted to. That is cheap paying freight. Just like poverty rock (brick) and shingles. All cheap freight.
   / Working rail roads and their tracks. #2,234
Got a couple pics of East Penn Monday
   / Working rail roads and their tracks. #2,235
Anyone ever hear of the "redstar graveyard"? Saw a little bit of this place watching the TV tonight. Wonder if there's a train "graveyard" like that in the US?
   / Working rail roads and their tracks. #2,236
There are a lot of engine storage areas, and unused cars sitting on sidings, all over the country. But I haven't seen a graveyard. I'd guess most are recycled/scrapped if there're no parts of value here in the U.S.
   / Working rail roads and their tracks. #2,240
Railroads seem to have the most waste of any industry I’ve ever seen. Thousands of miles of abandoned steel rails rotting away across the country, real estate under them just left abandoned, engines and rolling stock left to decay. Little attempt (at least that I see) to scrap anything, clean anything up, recycle.
It doesnt seem like other industries leave so much behind and unused?
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2015 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2015 Chevrolet...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A53422)
2019 Ford F-350...
