MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,132
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Looks like she's about due for a paint job.Naubinway, Michigan - CN L544-06 - Southbound through the birch and pine trees 02-06-26 View attachment 5058145
CN isn't too worried about paint on their locos, it seems. I see 'em faded pretty good. After CN bought Illinois Central, it took them a LONG time to convert the black IC locos to orange/black. I think the black IC locos looked better, though.Looks like she's about due for a paint job.
That probably happens in all industries. Redundant (or perceived redundant) services are first on the chopping block.I read somewhere that every time one RR buys another, maintenance on everything suffers are they get larger and larger....
Union Pacific Steam Club Update No. 44 - Feb. 24, 2026 | |
Double door boxcar with end doors, on its side. Took a minute since I thought is was simply a derailment, and I couldn't ID the car type.Copper Range derailment in Houghton MI. Photographer and date unknown. B&W rescue from a color slide. The lift bridge is seen the the background so its 1959 or later.View attachment 5200106
I've not seen those end door cars before.Double door boxcar with end doors, on its side. Took a minute since I thought is was simply a derailment, and I couldn't ID the car type.
Bruce
This image that popped up on X.
But there was no commentary, so I GTS. And found this post on Reddit. With this pic...
... and this info in the thread.
It was GG1 #4846 involved in a wreck, some time under Penn Central. Workers at the Wilmington Shops used what was left and made a snow blower out of it.
According to couple old timers who worked at the shops (through the "We Salute You GG1 Facebook group), it was built without the knowledge of PC corporate management. As far as the PC knew, #4846 was already scrapped. If corporate visited the shops, it was parked on a siding behind the wheel shop where tall weeds grew, out of sight.
It was used to remove snow from the switches of the Wilmington Shops. It didn't track well, with the weight of the drivers too heavy on the rear. They said it used to run under its own power but derailed too much, with no trailing truck. If too much was put on the throttle, the lead truck would lift above the rails.
Later it ended up being pushed around by a diesel switcher, with the pantograph only to provide power to the blower that blew the snow. The "chopped" end has the blower duct pointing down at the track. It sounds good in concept but wasn't very practical. Apparently it was a little overpowered and would blow away ballast. It was scrapped around '83(?).
I'm not sure how accurate I am, l tried to stitch multiple old timers' recollections from the 70s-80s together, from comments on a facebook group nonetheless. So take it how it is. I could swear there was a book that had info on this unit but I couldn't find it.
TLDR; It was a snow blower used in the Wilmington DE Shops, built from the remains of wrecked GG1 #4846.
Found this pic on faceplant.
I guess that's what happens when you leave the guys in the shop alone.
And I guess the first picture was photo chopped to add the NYC logo/paint.![]()
Nearly every company for which I've ever worked has had one or two "Skunk Works" projects, some pet project of the Engineering Manager or similar, that's been kept secret from executive management. But the hardware is usually a heck of a lot smaller and easier to hide than a locomotive.I guess that's what happens when you leave the guys in the shop alone.
