Working Off Of a Front Loader?
   / Working Off Of a Front Loader? #1
Anonymous Poster
Epic Contributor
Hi,
The other thread concerned walking under a loader. Bad practice! Best to be avoided as others have said.
But how about working off the loader? Wouldn't that be "almost" as dangerous?
All the things that could go wrong to cause the loader to crash down and crush someone, could also cause the loader to crash down with someone in it, or in/on a platform attached to it...
I know it's better land on top, rather than have it land on you, but still...
I guess it's a gamble...but seems like one we are willing to live with...or should that be "live" with...?
Bill in Pgh, PA
   / Working Off Of a Front Loader? #2
I work out of mine limbing trees, getting on the roof, and such. I like it much better than a ladder.
When you think of firemen, powerlinemen, construction lifts, we all trust hydraulics to a point. Inspect you hoses and fittings. All things mechanical can fail at any time.
   / Working Off Of a Front Loader? #3
it's not that i would not trust the hydrulaics, i use manlifts and sky lifts at work, i just don't think a fel is a good working platform. but that is just mho.
   / Working Off Of a Front Loader? #4
I, too, have worked out of an FEL trimming limbs. Not my favorite thing to do but sometimes there is no other good way. My neighbors big International FEL goes up about 12' and that gets a little scary./w3tcompact/icons/shocked.gif And the potential for a cut limb pulling you out is certainly there. I have only done it out of his a couple times and was careful to the point of being ****, but????????????/w3tcompact/icons/crazy.gif
   / Working Off Of a Front Loader? #5
I do a ton of work off of mine. Whenever I've built a house or a barn the loaders are the handiest tools. I don't see how it's much more dangerous than using a skillsaw or a ladder. I'd much rather be 20 feet up in the air in a loader bucket than a ladder anyday. If you're smart and watch what you're doing you should be ok.
   / Working Off Of a Front Loader? #6
It's funny you should ask....
I have spent a few hours up in the air with chain saws cutting limbs while my father-in-law moves me around in the bucket of his '55 Ford. ( I am very, VERY good to his daughter /w3tcompact/icons/grin.gif!!!)Probably not the safest, but I have always thought of tree work as risky anyway.
I got pallet forks for my new tractor and am going to build a "scaffold" platform to do some house siding work. I plan to join two 4-foot pallets with beams into a 4x8 platform and make a permanent 3-sided safey railing with a removeable 4th-side rail. I also plan to "rest" the assembly against the wall in case the hydraulics fail or bleed down. Finally, I plan to used wheel-chocks to prevent rolling. My loader arm has a boom "lock-out" switch which prevents unintended boom movement.
If there is anything else to consider, I would appreciate the suggestions.
Mark
   / Working Off Of a Front Loader? #7
I put together this platform in a few hours. Lucky that the tractor is equipped with a quick detach for the bucket, just takes a minute to change.
   / Working Off Of a Front Loader? #8
That's EXACTLY what I had in mind, except pick it up with the pallet forks. Is it metal or made of wood?
Mark
   / Working Off Of a Front Loader? #9
It is made of metal. I put a 3/4 inch plywood floor in it though. At first it was just the bottom without the rails, I used it to lift the stove, piano, fridge up on the deck for the house. I did stand on it to do some tree trimming, but the rails not only keep you in, they are great to lean against when reaching out. I have one of those extendable chainsaws, with the lift I can reach a little over 25'
   / Working Off Of a Front Loader? #10
The most dangerous thing I do every day is get into my car and drive out on the road. Everything else by comparison is less dangerous. If I want to live my life in fear, I could. But I don't. Warning people of dangerous things is fine. But doing dangerous things, in my opinion, is part of my life. I won't stop driving my car.
If I need to get up in the air, and I think I can do it in the bucket of my tractor, I will. I will plan to do it as safely as I know how.
When I was 16, I was spray painting the side of a barn that was about 50' to the eaves. The 40' extension ladder didn't reach that high. So the son of the farmer and I put the 40' ladder in the bucket of the little "C" Farmall (maybe it was even a "B") and raised the ladder the extra 10' needed. It worked well until it became tiring coming down every time to move the ladder over a few feet and then go back up to spray the next strip of barn. So the farmers' son and I thought if I would stay on the ladder, he would jockey the tractor around on the ground to move parallel to the barn, and I could stay on top and position the ladder. Worked well until the rear wheel of the tractor dipped into a hole. Down along the barn came ladder, paint bucket, and spray equipment, along with me on top. The top of the ladder landed on a 12" oak post at the corner of the barn, and I went through the ladder breaking it into many parts and pieces. When I stopped, I was standing on the ground amongst the broken ladder pieces and sprayer parts, with my hand resting on top of the 12" oak post. No more jolt than stepping off a chair. Yes, I think I was very lucky. Did we finish spraying the barn? Yes, but first had to get another 40' extension ladder. No other way to paint it, that we could figure out. /w3tcompact/icons/smile.gif
2016 Ford Explorer SUV (A51694)
2016 Ford Explorer...
Paint Dryer, Briggs 5.5 (A52384)
Paint Dryer...
1995 VOLVO BM A25C 6X6 OFF ROAD WATER TRUCK (A51246)
1995 VOLVO BM A25C...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53473)
PENDING SELLER...
2020 BOBCAT T770 SKID STEER (A51246)
2020 BOBCAT T770...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
