working M7040
/ working M7040 #1
m7040
Elite Member
Frederick maryland
Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
this is what a hard working M7040 looks like after a long day of dirt moving
/ working M7040 #2
Good looking day of work. :)
/ working M7040 #3
Come on now, you can do better than that. Mine gets dirtier than that in about 30 minutes of feeding the stock! Just ribing ya. Nice tractor by the way, looks just about like mine.
/ working M7040
Cummins, thanks for your comments .... yes i love the tractor too. dont know if you noticed but I have added a remote control spotlight in place of the left front upper worklight. It works great
/ working M7040 #5
What type of wheel weights do you have on rear? I am considering the same. Wish I had gotten the cast iron disc.
/ working M7040
blk, yes I changed to CI hubs that I think added 600 lbs per wheel and then bolted on cast iron center weight that adds 200 lbs per wheel and now adding two more weights per wheel. So will have total of 1200 lbs per wheel in cast iron and 800 lbs of fluid totalling 2000 lbs per wheel plus ballast box when needed weighing 2000 lbs. Tractor is 7000 lbs I think plus then 6000 lbs in added weight totalling 13000 lbs. Traction is very good indeed virtually no slippage
/ working M7040 #7
Great tractors, gents.
As someone here at TBN has often said: "Power is Good - So is Weight" ;)
/ working M7040
You need power and weight to do work efficiently
/ working M7040 #9
That's a mighty fine rig you have there. (Tractor envy at bigger tractors than mine).
What kind of 4in1 bucket is that? WR Long?
See what you started...one picture is just not enough...
/ working M7040
thanks for those comments, it is a Bradco 4inone bucket and works just great for me
