Working lights
   / Working lights #1
stevejd990
Alaska
John Deere 990
I have a JD 990 on which I want to add working lights on the ROPS for plowing snow. Above the rear axle on either side of the ROPS, there is a "T" shaped connector, female as I recall. Is this wired to the existing switch on the dash? Also, does anyone know what the description of that "T" shaped connector is so I gan go to NAPA, or????? and get the male end.
Thanks,
Steve
   / Working lights #2
I'd also like to know what the designation of that connector is. For now I used two female spade terminals but would rather use the right connector.
   / Working lights #3
It sounds like the same connector as I have on the back of my 2210. If so it's the same as a mid 80's Toyota connector and can be found at wrecking yards on 82-85 Celica's and Supra's in quite a few locations. The license plate light at the back is the easiest one to get. It may also be possibhle to find it on other years and models of Toyota's and possibly other Japanese cars. If you post a pic I can tell you for sure.
   / Working lights #4
Ray I owned a 2210 and your correct it is the same connector. Thanks for the info.
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
(1) 24' CORRAL PANELS W/ (1) 12' GATE (A51243)
(1) 24' CORRAL...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
