Workbench top
/ Workbench top
Thanks for all the replies and pics too!
A couple of comments and questions...
My workbench is not a primary workspace. It's for the odd job that won't need many tools. I don't store much beyond my machines and surplus goods in that building. It's not very good "work" space.
My base construction has two overhangs. First the large one to the right, but also the front has about a 2 1/2" lip from that 2X8 laid on its side.
For those that have used a hardwood, either strip flooring or tread or whatever... how did you fasten it down? Did you use a "subfloor"?
For the metal topped benches, is everyone just using cheap HVAC sheetmetal?
Anyone have an opinion on using cement board (like Hardie backer as opposed to Durock)? It would probably have to have some angle iron on the edges, but I could see that lasting a long time if it had 3/4" ply underneath.
I'm not sold on butting dimensional lumber together for the top. The only plus for that option would be not needing a seam due to the >8' length. But I can see having to belt sand all that area to get rid of the eased corners of each stick.
Anyway, thanks again. I hope this thread will provide some good ideas for folks who are thinking about building a nice sturdy workbench.
/ Workbench top #32
I used just 2x6 for mine, but there are several options. Like the Coop in Marshal sells oak boards (1.5") for trailer flooring. That would be a great bench top.
Or Grizzly Ind. carries maple glued bench tops for OK price, check them out.
/ Workbench top
I agree that I like the idea of a nice chunky oak. Is the T&G? Marshall's an easy drive south for me.
I see plenty of 1X6 rough sawn fence rails, but by the time it's planed down it'd be nothing.
/ Workbench top #34
My first workebench was a thing of beauty. My second work bench was also just short of cabinet grade. Then I started cutting corners and not spending very much time building them. I found that in spec homes, I could put a simple work bench in the shop and it helped sell the house. Now I just use OSB for the top and trim the edges with 1/4's.
Worse case is that I destroy it and have to spned $8 on a new piece of OSB. I've never had to do that yet, but it's an option if I ever have to.
Eddie
/ Workbench top #35
The face butted 2x material was run through a large planer
/ Workbench top #36
I was at a yard sale buying used cabinets and saw a 3' x 6' piece of 1 3/4 thick maple butcher block in the back of the garage. The owner said he forgot that he had it and I got it for $15! When I built a workbench around it my wife commented that it was a piece of furniture not a work table. I cut a piece of 1/4" masonite to protect the center of it when doing major pounding. It has held up well.
/ Workbench top #37
They actually sell butcher blocks for workbench tops...:thumbsup:
/ Workbench top #38
I would not use any type of cement board as a top ply working surface due to the possibility of it cracking or chipping. I'm very pleased with good old 1/4" (+-) tempered Masonite at a far less cost.
/ Workbench top #39
I topped mine with pieces of scap plywood and then covered that with Pre finished Hardwood flooring scraps, It's bombproof! Random colors but looks good. If a board gets too abused I just cut it out and drop a new one in.
/ Workbench top #40
I agree with Nickel Plate - stay away from cement board. It is too abrasive, brittle, hard to cut, dusty, etc......... I made several from scrap waterbeds. Usually straight 2x6s and or 2x8s, stained and finished.
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
RK25 PERFORMANCE SERIES TRACTOR (A62130)
RK25 PERFORMANCE...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
Utility Cart (A59231)
Bobcat S205 (A60462)
