Work Platform/Lifting Platform
   / Work Platform/Lifting Platform #11
Great project. I also noticed when I used my FEL mounted pallet forks for the first time that the dump function goes much faster than the curl function, which can be feathered easier. I further noticed that the dump function dumps much faster when there is a load. The heavier the load, the faster the dump!
How much ballast did you need to lift the Quad? Did you have your backhoe attached at the time?
   / Work Platform/Lifting Platform #12
akpilot said:
Wedge
The QA plate I built, w/1/4" plate and 2&3" 3/8 strip steel. The Sq tubing for the main frame is 2" 1/4" wall, 7' from QA plate to the end, the short risers between the platform boards and the strip steel on top are 1 1/4" x 3/16" with 2"x12"x8' platform boards.
I added one picture that shows the QA plate a little better and one pic that shows part of the storage area (part over the office), the other part (to the right) is over the wood shop with a little ramp in between. As you can see the shop is still under construction, hopefully I can finish it this year. :)
Thanks for the info and photos. Your shop is very interesting. Nothing like using wasted space to the max. The quads look like they are ready leap out and get you.
   / Work Platform/Lifting Platform #13
Great looking platform. Sturdy and functional are great qualities for such a platform. That backstop/hand rail will be great security for working off your platform.
I have seen the high lift loaders from Frey, in pictures. But probably no matter how high the lift a "little bit more is eventually going to be needed.:rolleyes: That just seems to be the nature of things.
Mike
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
LOT: Welding Accessories: (2) Auto Darkening Helmets, Welding Rods, Welding Wire, Magnetic Arrows (A59076)
LOT: Welding...
2006 KENWORTH T300 DAYCAB DIGGER TRUCK (A58214)
2006 KENWORTH T300...
2015 Freightliner M2 106 4x4 Altec DM47B TR 47ft Digger Derrick Truck (A55973)
2015 Freightliner...
