Work mode doesn't work
   / Work mode doesn't work #1
Interceptor
PA, USA
Deere 4120, Deere 355D, Toolcat 5600
I recently bought a 2012 5600 (Series F). I've never been able to get work mode to engage. The indicator lights up during bulb test so I know the indicator works. The work button works for the setup functions so I know the switch is good. I understand work mode doesn't function when in high speed. Are there any other common conditions that would prevent it from turning on? I don't have an operator's manual, but I believe work mode should turn on just by pressing the work button, correct?
   / Work mode doesn't work #2
That is how I understand it to operate.
Now that I'm getting to know the machine a little better I've discovered that work mode is functioning. I can feel a change in the pedal response when I press the button, but for some reason the light just doesn't turn on. Must be a problem in the logic that controls the light.
   / Work mode doesn't work #4
I have a 5600-D. I've never really seen the advantage/use of "Work" mode. Yep, the pedal behaves differently. My running supposition is that when one is not in Work Mode you are in Play Mode.
Interesting. I find it to be very useful. Maybe the D series is tuned differently than the F series. I've only put about 10 hours on my TC, moving pallets with forks, moving logs with a grapple, moving stone with a bucket, I prefer work mode for everything except just traveling from point A to B. Finer control at low speeds and no difference in maximum speed. The only time I'm not in work mode is when I'm in high speed. I think the default mode has too much roll out after the pedal is released. Work mode responds more like my Brutus (mechanical hydro) and my 4120 (E-hydro).
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56438)
2018 John Deere...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2014 NISSAN NV CARGO VAN (A59575)
2014 NISSAN NV...
11' CONTAINER (A52706)
