WORK LIGHTS
   / WORK LIGHTS #1
BX23RIDER
Beech Creek PA
KUBOTA BX23
I PUT TWO 55W LIGHTS ON THE ROPS & CONNECTED THEM TO THE TWO WIRES UNDER THE SEAT, THAT GOES TO A 20AMP FUSE MARKED WORK LIGHT BY THE BATTERY. I WILL NOT BE USING THEM ALOT 30 MIN OR SO. DO I NEED THE HIGHER OUT PUT ALTENATOR ?. WILL IT HURT ANYTHING USING THE ONE IT COMES WITH. THANKS BX23RIDER. PS I DO ENJOY YOUR DISCUSSIONS.
   / WORK LIGHTS #2
IS IT REALLY LOUD WHERE YOU ARE? IF IT IS, I'LL KEEP SHOUTING SO YOU CAN READ THIS.
All kidding aside, welcome to TBN! I have a BX22 that I rigged the same way. You should be fine with that setup and the stock dynamo. I've use my lights and headlights at the same time for hours at a time while shovelling snow without any problems.
   / WORK LIGHTS #3
I don't think you will have a problem as long as you don't run any other high draw equipment at the same time. I think two 55 watt lights draw about 11 amps. I run one 55 watt halogen on the rear with the same hookup as you. I can run it along with the headlights and flashers and I have had no problems.
Dean
   / WORK LIGHTS #4
I run (2) 55 watt facing forward and (1) facing rearward on my BX1800 with the stock alternator and have had no issues. I don't run the stock lights at the same time, but do sometimes run the flashers when near the road.
   / WORK LIGHTS
THANKS FOR THE INFO, NOW I CAN SEE WARE I AM GOING. HA HA. /forums/images/graemlins/smile.gif
   / WORK LIGHTS #6
Randy, do those lights have a magnetic base?
Do you have any pics of your plow and receiver hitch? I'm just curious about how you put it together.
Dean
   / WORK LIGHTS #7
The basic formula used is P=I*E or watts=amps * voltage. Using basic math to solve the equation when amps is the unknown, you would have amps=watts divided by voltage.
So for two 55w bulbs you would have an amp draw of just over 9 amps. Three 55w bulbs would draw about 13.75 amps.
I believe the standard dynamo on the Kubota's is 14 amps. Exceeding a 14 amp draw will discharge the battery faster than the dynamo can recharge it.
   / WORK LIGHTS #8
I should never do multiplication without a calculator. /forums/images/graemlins/smile.gif
   / WORK LIGHTS #9
Funny, but I just came to the site to see if anyone hooked up a light recently. I just hooked up a 35Watt to my ROPS, but using a seperate bracket. My tractor will not fit in the garage with the ROPS up, so I use it with it down. In fact the bracket is removavble because with it mounted it is too high to get in my 7 foot door. I know I shouldn't run with the ROPS down, but it just gets in the way too much. I spliced my light into the rear running lights so I could use the main switch.
Question - I gues Kubota does not use a grounded system since there are two wires to all the lights. The light I bought was for a grounded system. I connected the ground to the light mounting screws. Any comments?
B7800, SB, York Rake, RM, FEL w/ teeth, 145 hours of fun /forums/images/graemlins/smirk.gif
   / WORK LIGHTS #10
Two things: Just went outside and tried the single 35 Watt light - Wow! Last winter I blew my 1/4 mile driveway using the light from the amber turn signals with the 35W light I think I will enjoy this much more.
Also, I got my Fluke out and verified that the wires under my B7800 seat are for accesories and the Black is grounded to the chasis, so I take back what I said about an ungrounded system. I guess they just want to make sure of a good circuit which will not be affected by corrosion.
I look forward to the first snow - oh yeah and the last in May too! /forums/images/graemlins/smile.gif
2015 KENWORTH T270 SERVICE TRUCK (A51406)
2015 KENWORTH T270...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2023 Club Car Carryall 700 Utility Cart (A54811)
2023 Club Car...
2005 Sterling Acterra Tender Truck (A55301)
2005 Sterling...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A53421)
2017 Toro Z-Master...
