Work Lights on TC 45
   / Work Lights on TC 45 #1
GaryC
Southlake Texas
New Holland TC45D SS
I was needing a little advice. I have a TC45 with a loader. When trying to finish mowing when it is getting dark, my headlights are somewhat blocked by my loader. Does anyone have front and rear facing headlights mounted high on the rollbar or on an open air canopy? I do have alot of low hanging branches that hit my canopy and I believe I would break not so tough lights that were mounted to it. My thoughts go to some kind of "quick connect" halogen lights that I could snap on at dark and leave off when mowing in the trees during the day. I would appreciate any thought or insights into this. Thanks in advance.
   / Work Lights on TC 45 #2
I'd suggest putting the lights on the <font color="blue"> inside </font> of your ROPS. Point them slightly down and put them low enough that light doesn't get blocked by the canopy. That way you can mount them semi-permanently and not have to worry about destroying them, even if you do run your canopy into something. ...my suggestion. Good luck.
   / Work Lights on TC 45 #3
I can't speak from experience, but I do know that it seems this topic surfaces almost every other week or so. If you do a search for lights , or work lights , or whatever, you'll find more information than you'll know what to with! /forums/images/graemlins/wink.gif Just use the search feature at the top of the page. And remember to take and post photos of whatever you end up doing. We all want to see other ideas! /forums/images/graemlins/grin.gif
   / Work Lights on TC 45 #4
Gary, Check the past posts for lighting. I left detailed instructions for exactly what you are looking for back in the fall. I have a new TC35D and it is quite a process in hooking up the switch. My lights are mounted high up in each corner of my canopy. Good Luck
   / Work Lights on TC 45 #5
See attached pic. I added them to mirror stalks I mounted on the loader frame.
Mark
   / Work Lights on TC 45 #6
Mark,
How did you mount the mirror stalks on the loader frame? Did you drill extra holes, use a clamp or what? How did you wire them in? Are they an addition to the OEM lights or did you disconect the OEM lights? Thanks
Joe
   / Work Lights on TC 45 #7
The mirror/light stalks are 1" box steel about 3ft long. There are already 2 holes in each of the loader uprights under the safety stickers. I just punched through the stickers, drilled the box steel, and bolted them on. The lights are bolted into holes I drilled and the mirror heads (trailer mirrors - mild wideangled) are directly behind the light heads.
For wiring, I first tried to tap off the headlights, but the load was too much. I changed it so I have a relay (so they only come on when the headlights are on) and pull power from the battery. The switch from Lowes snaps right into one of the blanks on the dash (attached pic). The stalks ground to the tractor, so I only had to run hot wires.
Only complaints: I bought driving lights when I should have bought flood lights & the mirrors don't stick out far enough for my satisfaction.
Mark
   / Work Lights on TC 45 #8
Another view of the mirrors.
Mark
   / Work Lights on TC 45 #9
Mark,
Thanks for the additional info. Now I know which way to go.
Joe
2018 Ford F-350 4x4 Ext. Cab Stellar FC3200 3,200lb 1.5 Ton Service Crane Truck (A55973)
2018 Ford F-350...
2018 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A55973)
2018 Ford F-350...
LOT: (3) NEW Hi-Run 26 x 12.00-12 Lawn & Garden Tires (A59076)
LOT: (3) NEW...
CORN SHELLER MOUNTED ON WOOD BOX (A58374)
CORN SHELLER...
PALLET OF FISHING GEAR (A58374)
PALLET OF FISHING...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
