work light power feed for 3720 open station
   / work light power feed for 3720 open station #1
fishhead
Howdy, hoping someone can point me toward the color and location of the leads for the work lights on a ROPS 3720. I thought i had read some where that they are just sitting somewhere in the rear of the tractor waiting to be tapped into.
Thanks
   / work light power feed for 3720 open station #2
Prolly a connector tied up there too.. and I'd look to the left of the seat at the rear (facing the rear).
Thanks,
when you say facing the rear, do you mean looking backwards (i.e. to the right if seated and driving ?
   / work light power feed for 3720 open station #4
"facing the rear" meaning looking at the rear... not the front.
Sitting in the seat, to the left.
That is where mine was located. Doubt the 3720 is different, but could be.
i imagine you are right, i'll look in a bit. i noticed that the light switch has a separate position for work lights plus headlights so you would think that they would have a lead run to the back
   / work light power feed for 3720 open station #6
It's there... for you to find. :D
thanks again,
had to make a trip to bc for a couple of days, will revisit this in a bit
   / work light power feed for 3720 open station #8
   / work light power feed for 3720 open station #9
So it looks like there may be two connectors for adding the rear work lights.. maybe that will make it easier to locate them.. ;)
Oldtink, Been there
thanks for your replies, did not realize they had been made,
i ended up just tapping into the power feed for the taillights- works fine but probably not ideal, this does allow the option of combining flashers with work lights which i believe i could not do using the stock set-up
I never did find the work light feed, need to take another look, with all the stuff for 3rd 4th and 5th hydraulic hook-ups its a bit crowded it that area
I ordered a service manual, so when it comes in i should be better equipped
Thanks again,
if i do find those wires i'll post a pic and location so someone searching can find it
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
MASSEY FERGUSON SEAT (A58374)
MASSEY FERGUSON...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
Weld on excavator thumb EK1212 (A56435)
Weld on excavator...
Bucket (A55973)
Bucket (A55973)
2003 Ford F-750 Truck Highway HM25 Hydraulic Pressure Digger Truck (A55973)
2003 Ford F-750...
