work light brush guards - new and improved
   / work light brush guards - new and improved #1
boughtaJD
mid Michigan
JD 2320
When I purchased my 2320 back in March I went with the front & rear work lights as part of my deal. Brush guards for the rops-mounted turn/warning lights are required since that's what JD mounts the front work lights to. What I found from experience (either by one of my teenage sons or myself) is that 1) the unprotected worklights are easily damaged if a errant tree branch decides to pick a fight; 2) the rather wimpy steel JD brush guards don't measure up in my wooded areas either; 3) like others have posted about the JD worklights - the glare in your eyes when you look a little off center is harsh.
Solution: hit the junk pile, find heavier steel & start welding. I considered magnet-bases for the lights like some guys have, but I already paid for the JD work lights and needed better protection for my turn signals.
This picture shows the final product. Along with the fire extinguisher & 18" of pvc pipe with drain cemented in the bottom that I mounted to the SMV triangle mounting bracket. I moved the SMV triangle behind the seat. The pvc pipe holds my 5/16 20' chain perfectly.
The work lights are set back a little bit in the new and improved brush guards so the glare is cut down some. The work light on the left is cracked so I used a little clear tape for now. At $50 to replace the light the tape will do until I splurge for HID or LED lights down the road...
just for fun.. a pic of the komatsu D39 I used for 40 hours leveling out some pastures around one of our ponds. 4x the hp of my 2320 was a good time...
   / work light brush guards - new and improved #5
Those guards are a great idea. I'm tired of my lights getting knocked out of position every time I mow. If they do a good job of keeping the glare out of your eyes maybe you could post the dimensions for those that want to make some.
I think they're about 13" tall, 6" wide and 4" deep, but I'll get out the tape tonight.
   / work light brush guards - new and improved #7
Gee, not bad at all.
Ok for anyone interested - actual measurements are 12.5" tall, 6.5" wide, and 4" deep.
   / work light brush guards - new and improved #9
What is the diameter of that pvc pipe that holds your chain? A picture would be nice.
When I received my new JD I found that the dealer had mounted my SMV right over my rear light so it shaded it.
   / work light brush guards - new and improved #10
I think the work light brush guards mounted to the side of the ROPS is clever: How are they fastened?
1987 International S1900 Flat Bed Truck (RUNS)(TITLE) (A50775)
1987 International...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2014 Toro Workman HD 07369 Utility Cart (A55851)
2014 Toro Workman...
New JMR Skidloader Stump Bucket (A50775)
New JMR Skidloader...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
