Tiller Woods Tiller Oil Seal Replacement
   / Woods Tiller Oil Seal Replacement #1
AGSAVL
Western NC
Kubota B7510DT
Two years ago I purchased a used 2004 Woods GTC52 tiller along with a Kubota B7510. After one use I noticed an oil leak where the rotor enters the frame and chain housing.
I have purchased a new oil seal, and was told by the local dealer that the seal can be replaced from the outside, meaning the rotor doesn't have to be removed to reach the bad seal.
Upon removing the chain and sprockets I am left with a bearing that blocks access the the seal and no obvious way to remove it. Can this bearing be pulled to access the seal or does the frame need to be disassembled and the rotor removed?
I am attaching photos of the bearing as well as the parts diagram from Woods. The bearing is #6 and the seal #62, bottom center of diagram.
Thanks,
AG
   / Woods Tiller Oil Seal Replacement #2
AG,
It looks like you'll have to remove the 2 bolts # 46 from the side plate . That should allow you to remove the side plate. HTH
T-Man. :cool:
   / Woods Tiller Oil Seal Replacement #3
I just finished doing this same job on my tiller on Friday. Mine is a Challenger but is very similar to your Woods. I had to remove the opposite end face plate (3 bolts) which allowed me to remove the rotor easily. The bearing and seal are in one, removable housing. I unbolted it from the chain side face plate, popped out the old seal and replaced it in about 10 minutes. Reassembly was quite easy after that and I am back in business.
PS: I did not buy the gasket for the chain case because it was $48.00. A tube of blue silicone works very well for this purpose and is a whole lot cheaper.
   / Woods Tiller Oil Seal Replacement #4
I did my Agric Tiller last year. I had to pull the rotor. The seal was on the back side of the short jack shaft seen in the photos. A lot of work for a $6 part! Worth it in the end though, replaced some very worn tines too. Wish my garage looked like some I have seen here but the job got done.
I really appreciate the replies. I'll pull the rotor tomorrow and see what I find.
AG
   / Woods Tiller Oil Seal Replacement #6
How did you get the bearings out to get at the old oil seal? thanks. Matt
2007 Sterling L9500 National Crane 1800 40 Ton Tri Axle Telescopic Crane Truck (A55973)
2007 Sterling...
1995 Rinker Captiva 190 (A56435)
1995 Rinker...
NEW Wolverine 36in Skid Steer Grapple Bucket (A59000)
NEW Wolverine 36in...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
