Backhoe Woods subframe to CT230
   / Woods subframe to CT230
Thanks Tfish, it would be helpful to see the fit-up on that at the front end. Do you know who built the loader on your CK30? I believe that any differences between the Bobcat and the Kioti are related to The FEL mounts.
   / Woods subframe to CT230 #12
The loader on my ck30 is a kioti. I'm out of town right now but when I get home I will try to figure out how to put a picture on here... but the connection in the front was simple but I was able to just order a subframe from woods to put the woods backhoe on my tractor..I'm surprised that they can't make you one, that's what they did for me because they had discontinued the subframe I needed.
   / Woods subframe to CT230 #13
I'll attempt to upload a couple of photos here... it's the left front mount for the FEL, with the subframe mounting tab that would be used for the backhoe subframe. Is this different from the Kioti with it's FEL?
View attachment 489451 View attachment 489452
Dave - I must be loosing my mind, but I swear someone posted a pictures of the loader sub frame on their Kioti and it bolted to the two L tabs in your picture. These are the same tabs used for the belly mowers which I believe fit both. Il keep looking, but is somewhere or got deleted for some reason. Found it - post 23...but you already know that ;)
http://www.tractorbynet.com/forums/bobcat-tractors/310763-wanting-backhoe-ct-225-a-3.html
   / Woods subframe to CT230 #14
Dave I took a picture of the front mount on my CK 30 but can't figure out how to load it...but the front of the subframe bolts to the two L shaped brackets from the FEL. If it is only the front mount that is different on yours that should be easy to modify. the back mount is definitely more complicated...I must be brain dead but I can't figure out how to post a picture on here!
Yeah, those two L-brackets are the key, I think. They are a part of the FEL subframe, and could be different depending on the FEL that was installed. From all the discussion and comments, it appears that any modification would be "relatively" minor, though I don't relish the thought of either cutting and rewelding the subframe, or fabricating an adapter plate to make it work. I'm hoping for a straight bolt-up.
   / Woods subframe to CT230 #16
Give these folks a call. They used to be a Bobcat Compact tractor dealer and now sell Kioti. They have helped me out before on parts.
Legacy Tractor Sales & Service, Inc.
1845 North College Avenue
Fort Collins, CO 80524
P: (970) 482-4803 or 1-877-636-0500
Source: Resource Links
Well, I'll bump this post with the comment that I've pulled the trigger on the Woods BH75 backhoe for my CT230. I wasn't able to get all the info I wanted on how the subframe hookup is going to work, but from all indications, it should be relatively easy. I ended up going with the 12" bucket and a 24" bucket, and the mechanical thumb, of course.
Thanks to all who provided their insight.
   / Woods subframe to CT230 #18
Thanks for the update I'll bet you'll be pretty happy with it.
Ok! The Backhoe arrived today, so I think I'll start a new thread on the installation. It may be a slow process for a while, since I can't risk taking the tractor out of service with snow in the forecast. Also, Woods managed to "forget" to send the hose-kit, so I'll have to wait for that to arrive before actually mounting the hoe. I'll try to post pictures as I go.
2012 Freightliner Cascadia (A56436)
2012 Freightliner...
Case IH 330 Turbo Till (A59814)
Case IH 330 Turbo...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
Forklift (A56857)
Forklift (A56857)
Deere 310L (A53317)
Deere 310L (A53317)
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
