Woods RC - spewing oil?
   / Woods RC - spewing oil? #1
9973720wb19
Platinum Member
East Coast
Many
why is my 72' (farily new) Woods RC spewing oil out of the vent cap on top of the gear box? it's not a lot but enough that it's running down the sides of the gear box. :confused:
   / Woods RC - spewing oil? #2
Is it over filled? If not I've hear folks say it could be getting hot. Does it do it after a few minutes or when IRS been run awhile?
good questions. I'll have to check to see when it starts to come out. I think I'll let it run without mowing to see how long it takes to come out.
   / Woods RC - spewing oil? #4
I have that problem with a Phoenix. Shouldn't have to come up with a solution to solve the problem on a new mower:mad:
   / Woods RC - spewing oil? #5
First make sure it is not overfull. Take look at where the vent is located. If the vent is directly over the input gear the oil splash from the gear can go up the vent. If the bolt pattern on the cover is uniform, remove the cover and rotate it 90 or 180 degrees to move the vent away from the gear.
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
John Deere 825i Gator (A50514)
John Deere 825i...
1994 LUFKIN (A50854)
2011 GR TRAILER GOOSENECK (A50854)
2011 GR TRAILER...
Toro Workman Cart (A50322)
Toro Workman Cart...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
