WOODS MULTI-SPINDLES: Where's the catch?
   / WOODS MULTI-SPINDLES: Where's the catch? #1
Anonymous Poster
Epic Contributor
WOODS MULTI-SPINDLES: Where\'s the catch?
Hey, I want to maximize my cut width given a to-be-purchased tractor in the 40-45hp (35-40pto)range. I'd really like to go with 7', but everywhere i turn it seems that my range is 6. Then I saw these:
Model D80 & DO80 Belt Driven, Twin Spindle Rotary Cutters
Ok, not quite 7', but their requirements seem a whole lot less than other cutters.
Approximate weight 1,200 lbs.
Tractor HP 25 - 75
I want a cutter for pasture (25 acres)
So what's the catch? How does multispindle compare to single. Why such a big variance?
thanks,dave
   / WOODS MULTI-SPINDLES: Where's the catch? #2
Re: WOODS MULTI-SPINDLES: Where\'s the catch?
Dave, I think if you price one you will find at least one of the catches.
MarkV
   / WOODS MULTI-SPINDLES: Where's the catch? #3
My personal opinion is that with a 40 to 45 hp tractor (35-40 pto), you'll do fine with a 7 foot single spindle brush hog. I ocassionally use a 6 ft behind my NH TC 40D without problem. Are you planning on letting the fields get extremely long or is the grass/weeds expected to get extremely thick? I think if you find you're bogging down a little, just mow a little more often or raise the deck up slightly or slightly lower your ground speed. I've seen posts suggesting a 6 ft, but none that actually have a 7 ft and have had problems. If there out there, I'd like to hear from them.
   / WOODS MULTI-SPINDLES: Where's the catch? #4
Sounds like you need to check into a 7' disk mower. It would probably much more adept at handleing your needs.
UNUSED LANDHERO RIGGING/BINDING (A57193)
UNUSED LANDHERO...
UNUSED FUTURE FT-HJ6 40' METAL STORAGE SHELVES (A57193)
UNUSED FUTURE...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
2018 Chevrolet Colorado 4x4 Ext. Cab Pickup Truck (A53422)
2018 Chevrolet...
UNUSED PABREAK SBR160 SAND BLASTER (A57193)
UNUSED PABREAK...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
