Rear Finish Mower Woods mower drive shaft help
   / Woods mower drive shaft help #1
MillWeld
Durham NC
Ford 641
The drive shaft to my Woods mower wouldn't pull back from the over-running clutch far enough to disconnect the mower from the tractor. So, I just drove the tractor forward to free the mower drive shaft. I disassembled the sleeve around the mower drive shaft in an attempt to see what was causing the problem. No cause was apparent so I am now saddled with a thorny problem of trying to reassemble. There is a circular retaining spring with 3 "humps" on it which pass through slots in the sleeve to keep it from sliding. The hump can be seen in the 1st pic just above the flat surface on a grease covered plastic ring. I can't figure out how the sleeve slides over the retaining spring for the humps to mesh with the slots in the sleeve seen in the 2nd pic.
Got it repaired! No replies needed now.
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2015 Jeep Cherokee Latitude SUV (A55758)
2015 Jeep Cherokee...
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
New Holland T2420 (A53317)
New Holland T2420...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
