Woods MD172 problems
/ Woods MD172 problems #11
I've owned one for 20+ years. The poor thing has been treated roughly. It has "mowed" some trees that should have been cut with a chainsaw. After about 10 years, the oil level in the gearbox had to be topped off each use. There is a lower seal on the output shaft. Getting the blades off this unit is a cinch. Getting the crossbar a little harder. When I tried I came to a washer that was welded over the seal, so I gave up on changing it since I didn't own a welder at the time and carrying to one would be a pain.
I just fill it up each time. By now, it leaks pretty bad so I pretty much have to fill it every use. Last year, I tried a tip from an old timer and packed the case with grease. This worked pretty good but if you operate for a long time, the grease melts and leaks out anyway.
I still use it to bushhog about 80 acres a year plus making or maintaining trails in the woods. It has been a good one for me. I am looking to get a larger one, 10 or 12 footer, pulled type for open areas. After I finish all my hogging this year, I'm taking it to a shop for major overhaul, adding some heavier deck and side plates (after the sides are straightened :) ). I will reserve its use for brush and woods work and let the big one deal with fields and pastures.
THUNDER CREEK 460 GALLON FUEL TRAILER (A60736)
THUNDER CREEK 460...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2018 FREIGHTLINER...
ATTENTION PLEASE READ (A60462)
ATTENTION PLEASE...
2019 Chevrolet Tahoe SUV (A60352)
2019 Chevrolet...
