Woods M5
   / Woods M5 #1
Anonymous Poster
Epic Contributor
I am about to replace the blades on my 1970's Woods M5 cutter. I have the kit from Woods and am about to proceed. Aparently on the Woods mowers, there are easy to do. Does anybody have any tips?
   / Woods M5 #2
Wear gloves and get some PB Blaster (the TBN guys pointed me to this stuff). I bought some and it works extremely well on loosening rusty old nuts.
   / Woods M5 #3
Mowerfixer,
Great mower. I have had one for about three years and don’t think that I’ll ever trade. Raise up the back. Put jack stands under for safety. Remove top inspection cover. Turn blades to line up a blade bolt. Use ratchet and 5/8” socket to remove bolt. Knock pin out. Then reverse sequence.
   / Woods M5
Thanks...it sounds too easy, compared to what others seem to be saying on the board about changing blades...I'll try it this weekend and let you know what happens. Thanks much!
   / Woods M5 #5
Mowerfixer,
It is easy. The Woods blade system is second to none. I can change my blades in about ten minutes.
   / Woods M5 #6
Where can I buy this PB Blaster I hear so much about?
Eugene
   / Woods M5 #7
buppy69,
I picked up my last can of PB Blaster at the local Schucks. I'm sure most if not all big auto parts stores will have it. The stuff is about 100 times better than WD40 for loosening these nuts & bolts.
   / Woods M5
OK, so this afternoon, I got the bolts off and the "shim" plate things off...but the large "pins" that hold the blades on will not come loose. Tried hammering them down, but no luck. Any ideas...I'd guess these things have been on for 30+ years
   / Woods M5 #10
Never had that problem with a Wood's cutter. You really can't get a hammer to them. Let the PB Blaster soak for while then hold a short section of 1/2" or 3/4" pipe or rod in the center of the pin to hit. That way you won't burr the end of the pin.
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2014 Ford Escape (A50323)
2014 Ford Escape...
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
25077 (A51694)
25077 (A51694)
