Woods HD toothbar Help
/ Woods HD toothbar Help #1
jsduke
West Central Pa.
PT-425 (Former Kubota L3130 HST)
Hi All.
Just got my Woods toothbar (dealer). I had ordered a HD model for my round back bucket.
The one the dealer put on had a full length V shaped channel, which fit over the bolt on cutting edge on my bucket.
I don't know if the dealer installed the right bar /forums/images/graemlins/confused.gif. Is the HD bar configured this way or does it just have V shaped openings under each tooth?
Thanks.
duke.
/ Woods HD toothbar Help #2
While I only have the standard Woods TB, I believe the HD does use the V channel. They don't recommend using the standard bar which is basically the other type you mention. Some bolt on cutting edges are too thick for the V'd teeth instead of V channel.
The TB you have is probably much stronger as well. John
16ft. Field Cultivator (A65640)
16ft. Field...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2022 EZ-GO ELITE...
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
Case IH 5100 (A64119)
AR500 Deer Target (A65640)
AR500 Deer Target...
