Woods HD toothbar Help
/ Woods HD toothbar Help #1
jsduke
Bronze Member
West Central Pa.
PT-425 (Former Kubota L3130 HST)
Hi All.
Just got my Woods toothbar (dealer). I had ordered a HD model for my round back bucket.
The one the dealer put on had a full length V shaped channel, which fit over the bolt on cutting edge on my bucket.
I don't know if the dealer installed the right bar /forums/images/graemlins/confused.gif. Is the HD bar configured this way or does it just have V shaped openings under each tooth?
Thanks.
duke.
/ Woods HD toothbar Help #2
While I only have the standard Woods TB, I believe the HD does use the V channel. They don't recommend using the standard bar which is basically the other type you mention. Some bolt on cutting edges are too thick for the V'd teeth instead of V channel.
The TB you have is probably much stronger as well. John
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
Kubota RTV 500R-A (A64047)
Kubota RTV 500R-A...
MANCHESTER 80 GALLON AIR COMPRESSOR (A62131)
MANCHESTER 80...
KBH Tank Trailer (A63118)
KBH Tank Trailer...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
