Rotary Cutter WOODS Brushbull Rotary cutter
   / WOODS Brushbull Rotary cutter #1
bpsooner
Purcell, Oklahoma
Kubota M5040 with FEL, JD X320 Lawn Tractor
I recently bent my tailwheel assembly while mowing. Does anyone know if these are universal or would I need to replace it with a WOODS specific tailwheel?
Thanks
   / WOODS Brushbull Rotary cutter #2
I know that I have replaced the tail wheel yoke before on a 4' Woods Brush Bull that I used to own and when I did I just ordered it from Messicks and it came in quickly.
Best of luck!
   / WOODS Brushbull Rotary cutter #3
Are you sure you have to replace it? I bent mine pretty bad. I took it all apart and spend a few minutes with an eight pound sledge and it was turning again.... Otherwise, you likely have to get a "woods" brand to get the assembly right.
With the help of a press, torch, and a sledge it is working as new. It may not be pretty but it is working......
   / WOODS Brushbull Rotary cutter #5
I've managed to bend mine pretty badly twice. The story I heard is that you need to have the top link really loose so the wheel stays on the ground. My land is really hilly and there is a tendency for the mower wheel to come off the ground when I go through a steep swale...it swivels around sideways or backwards, the slams down again as I move through the swale. The forward motion of the tractor transmitted onto a wheel that is oriented sideways causes the bend.
If I manage to do this again, I'm going to weld some gussets at the base of the wheel fork, just above the wheel, to try to stiffen things.
BOB
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2014 Dodge Journey SUV (A50324)
2014 Dodge Journey...
2009 Subaru Outback AWD SUV (A50324)
2009 Subaru...
